This works but I would like to move lines 91-109 to void setup()
#include <SoftwareSerial.h>
SoftwareSerial BTserial(2, 3); // RX | TX
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include "RTClib.h"
RTC_DS3231 rtc;
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 32
#define OLED_RESET 4
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define red 8
#define green 9
#define blue 10
#define relay 11
pinMode(red, OUTPUT);
pinMode(green, OUTPUT);
pinMode(blue, OUTPUT);
pinMode(relay, OUTPUT);
digitalWrite(red , LOW);
digitalWrite(green , LOW);
digitalWrite(blue , LOW);
digitalWrite(relay , HIGH);
BTserial.begin(9600);
delay(3000);
// YEAR DOM MONTH HOUR MINS SEC
//rtc.adjust(DateTime(2021, 6, 3, 16, 59, 0));
//rtc.adjust(DateTime(2021, 3, 28, 1, 58, 50));//SPRING TEST
// rtc.adjust(DateTime(2021, 10, 31, 2, 58, 50));//AUTUMN TEST
DateTime now = rtc.now();
delay(30);
int winter = 10;
int summer = 3;
int ny = now.year();
int nm = now.month();
int nd = now.day();
int nh = now.hour();
int nmin = now.minute();
int ns = now.second();
int dow = now.dayOfTheWeek();
if (! rtc.begin()) {
Serial.println("Couldn't find RTC");
while (1);
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // initialize with the I2C addr 0x3C (for the 128x32)// Check your I2C address and enter it here, in Our case address is 0x3C
display.clearDisplay();
display.display(); // this command will display all the data which is in buffer
display.setTextColor(WHITE, BLACK);
display.drawRect(117, 25, 3, 3, WHITE); // Put degree symbol ( ° )
draw_text(0, 25, "TEMPERATURE =", 1);
draw_text(122, 25, "C", 1);
/*============Display Date=================*/
display.setTextSize(1);
display.setCursor(0, 0);
display.print(daysOfTheWeek[now.dayOfTheWeek()]);
char currentDate [16];
uint8_t thisDay, thisMonth ;
thisDay = now.day();
thisMonth = now.month();
sprintf (currentDate, "%02d/%02d/", thisDay, thisMonth); //add leading zeros to the day and month
display.setCursor(62, 0);
display.print(currentDate);
display.setCursor(102, 0);
display.print(now.year(), DEC);
int heat;
static int boost;
int nd = now.day();
int temperature_celsius = rtc.getTemperature();
int math_temp = temperature_celsius ;
int DST;
int winter = 10;
int summer = 3;
if (nm >= 1 && nm <= 2 )DST = winter;
if (nm == 3 && nd <= 24)DST = winter;
if (nm >= 3 && nd >= 25)DST = summer;
if (nm >= 4 && nm <= 9)DST = summer;
if (nm == 10 && nd <= 24)DST = summer;
if (nm >= 10 && nd >= 25)DST = winter;
if (nm >= 11 && nm <= 12)DST = winter;
if ( nh >= 0 && nh <= 6 )heat = 17 + boost;
if ( nd == 1 && nh == 7 )heat = 17 + boost;
if ( nd == 7 && nh == 7 ) heat = 17 + boost;
if ( nd >= 2 && nd <= 6 && nh == 7 )heat = 18 + boost ;
if ( nd == 1 && nh == 8 ) heat = 18 + boost;
if ( nd == 7 && nh == 8 )heat = 18 + boost;
if ( nd == 1 && nh >= 9 && nh <= 17 )heat = 19 + boost;
if ( nd == 7 && nh >= 9 && nh <= 17 )heat = 19 + boost;
if ( nd >= 2 && nd <= 6 && nh >= 8 && nh <= 17 ) heat = 19 + boost;
if ( nh >= 18 && nh <= 22 )heat = 20 + boost;
if ( nh == 23 )heat = 17 + boost;
if (nm == 3 && nd >= 25 && dow == 0 && nh == 1 && nmin == 59 && ns <= 5 && DST == 3) {
DST = 10;
// spring();
if (nm == 10 && nd >= 25 && dow == 0 && nh == 2 && nmin == 59 && ns <= 5 && DST == 10) {
DST = 3;
// autumn();
if (((nmin % 1) == 0) && ns == 0) {
delay(300);
Serial.println("---checking for heat requirement--- ");
Serial.print("Required heat = ");
Serial.print(heat);
Serial.print(". Actual heat = ");
Serial.print(temperature_celsius);
Serial.print(". Boost = ");
Serial.print(boost);
if (heat <= math_temp) { //cold
digitalWrite(blue , HIGH);
Serial.println(". DO NOT HEAT ");
if (heat > math_temp) { //hot
digitalWrite(red , HIGH);
digitalWrite(relay , LOW);
Serial.println(". PLEASE HEAT ME ");
int boostbutton = 0;
int bm;
int bs;
if (BTserial.available() ) { // Checks whether data is comming from the serial port
boostbutton = BTserial.read(); // Reads the data from the serial port
if (boostbutton == '1') {
bm = nmin;
bs = ns;
boost = 5;
Serial.print("BOOST ON ");
Serial.print(" ");
Serial.print("nm/bm ");
Serial.print(nmin);
Serial.print("/");
Serial.print(bm);
Serial.print(". ns/bs ");
Serial.print(ns);
Serial.print("/");
Serial.println(bs);
delay(30);
bs = ns;
digitalWrite(green , HIGH);
if (boostbutton == '0') {
bm = nmin;
bs = ns;
boost = -3;
Serial.print("HEATING OFF ");
Serial.print(" ");
Serial.print(nmin);
Serial.print("/");
Serial.print(bm);
Serial.print(ns);
Serial.print("/");
Serial.println(bs);
delay(30);
bs = ns;
if (boostbutton == '3') {
Serial.print("CURRENT TEMPERATURE ");
Serial.println(temperature_celsius);
BTserial.println(temperature_celsius);
delay(10);
if (bs == ns) {
// if (bm == nmin && bs == ns) {
Serial.println("BOOST over ");
boostbutton = 0;
boost = 0;
delay(600);
Serial.print("nmin/bm ");
Serial.print(nmin);
Serial.print("/");
Serial.print(bm);
Serial.print(ns);
Serial.print("/");
Serial.print(bs);
Serial.print(" DST ");
Serial.print(DST);
Serial.print(" nm ");
Serial.println(nm);
delay(900);
/*================Display Time================*/
char buffer [16];
uint8_t thisSec, thisMin, thisHour;
thisSec = now.second();
thisMin = now.minute();
thisHour = now.hour();
sprintf (buffer, "%02d:%02d:%02d", thisHour, thisMin, thisSec);
display.setTextSize(2);
display.setCursor(15, 9);
display.print(buffer);
/*=============Display Temperature=====================*/
display.setCursor(82, 25);
display.print(rtc.getTemperature());
display.display();
void draw_text(byte x_pos, byte y_pos, char *text, byte text_size) {
display.setCursor(x_pos, y_pos);
display.setTextSize(text_size);
display.print(text);
display.display();
