I attached the header the file because I could not find exactly what I needed. I appreciate any help.
DS1302.h - Arduino library support for the DS1302 Trickle Charge Timekeeping Chip
Copyright (C)2010 Henning Karlsen. All right reserved
You can find the latest version of the library at
http://www.henningkarlsen.com/electronics
This library has been made to easily interface and use the DS1302 RTC with
the Arduino.
If you make any modifications or improvements to the code, I would appreciate
that you share the code with me so that I might include it in the next release.
I can be contacted through Electronics - Henning Karlsen
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#ifndef DS1302_h
#define DS1302_h
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#define FORMAT_SHORT 1
#define FORMAT_LONG 2
#define FORMAT_LITTLEENDIAN 1
#define FORMAT_BIGENDIAN 2
#define FORMAT_MIDDLEENDIAN 3
#define MONDAY 1
#define TUESDAY 2
#define WEDNESDAY 3
#define THURSDAY 4
#define FRIDAY 5
#define SATURDAY 6
#define SUNDAY 7
#define TCR_D1R2K 165
#define TCR_D1R4K 166
#define TCR_D1R8K 167
#define TCR_D2R2K 169
#define TCR_D2R4K 170
#define TCR_D2R8K 171
#define TCR_OFF 92
class Time
public:
uint8_t hour;
uint8_t min;
uint8_t sec;
uint8_t date;
uint8_t mon;
uint16_t year;
uint8_t dow;
Time();
class DS1302_RAM
public:
byte cell[31];
DS1302_RAM();
class DS1302
public:
DS1302(uint8_t ce_pin, uint8_t data_pin, uint8_t sclk_pin);
Time getTime();
void setTime(uint8_t hour, uint8_t min, uint8_t sec);
void setDate(uint8_t date, uint8_t mon, uint16_t year);
void setDOW(uint8_t dow);
char *getTimeStr(uint8_t format=FORMAT_LONG);
char *getDateStr(uint8_t slformat=FORMAT_LONG, uint8_t eformat=FORMAT_LITTLEENDIAN, char divider='.');
char *getDOWStr(uint8_t format=FORMAT_LONG);
char *getMonthStr(uint8_t format=FORMAT_LONG);
void halt(bool value);
void writeProtect(bool enable);
void setTCR(uint8_t value);
void writeBuffer(DS1302_RAM r);
DS1302_RAM readBuffer();
void poke(uint8_t addr, uint8_t value);
uint8_t peek(uint8_t addr);
private:
uint8_t _ce_pin;
uint8_t _data_pin;
uint8_t _sclk_pin;
uint8_t _burstArray[8];
uint8_t _readByte();
void _writeByte(uint8_t value);
uint8_t _readRegister(uint8_t reg);
void _writeRegister(uint8_t reg, uint8_t value);
void _burstRead();
uint8_t _decode(uint8_t value);
uint8_t _decodeH(uint8_t value);
uint8_t _decodeY(uint8_t value);
uint8_t _encode(uint8_t vaule);
#endif
