Hi all, I’ve been having some trouble with getting my rtc module (https://www.sparkfun.com/products/10160) to work when I have a wifi shield connected. Whenever I run the rtc code without the shield on it works fine but as soon as I plug in the shield the rtc reports random times. Here is the code I am using
#include <SPI.h>
const int cs=8; //chip select
RTC_init();
//day(1-31), month(1-12), year(0-99), hour(0-23), minute(0-59), second(0-59)
SetTimeDate(21,5,13,14,29,00);
Serial.println(ReadTimeDate());
int RTC_init(){
pinMode(cs,OUTPUT); // chip select
// start the SPI library:
SPI.begin();
SPI.setBitOrder(MSBFIRST);
SPI.setDataMode(SPI_MODE1); // both mode 1 & 3 should work
//set control register
digitalWrite(cs, LOW);
SPI.transfer(0x8E);
SPI.transfer(0x60); //60= disable Osciallator and Battery SQ wave @1hz, temp compensation, Alarms disabled
digitalWrite(cs, HIGH);
delay(10);
int SetTimeDate(int d, int mo, int y, int h, int mi, int s){
int TimeDate [7]={s,mi,h,0,d,mo,y};
for(int i=0; i<=6;i++){
if(i==3)
i++;
int b= TimeDate[i]/10;
int a= TimeDate[i]-b*10;
if(i==2){
if (b==2)
b=B00000010;
else if (b==1)
b=B00000001;
TimeDate[i]= a+(b<<4);
SPI.transfer(i+0x80);
SPI.transfer(TimeDate[i]);
String ReadTimeDate(){
String temp;
int TimeDate [7]; //second,minute,hour,null,day,month,year
if(i==3)
i++;
SPI.transfer(i+0x00);
unsigned int n = SPI.transfer(0x00);
int a=n & B00001111;
if(i==2){
int b=(n & B00110000)>>4; //24 hour mode
if(b==B00000010)
b=20;
else if(b==B00000001)
b=10;
TimeDate[i]=a+b;
else if(i==4){
TimeDate[i]=a+b*10;
else if(i==5){
int b=(n & B00010000)>>4;
TimeDate[i]=a+b*10;
else if(i==6){
int b=(n & B11110000)>>4;
TimeDate[i]=a+b*10;
else{
int b=(n & B01110000)>>4;
TimeDate[i]=a+b*10;
temp.concat(TimeDate[4]);
temp.concat("/") ;
temp.concat(TimeDate[5]);
temp.concat("/") ;
temp.concat(TimeDate[6]);
temp.concat(" ") ;
temp.concat(TimeDate[2]);
temp.concat(":") ;
temp.concat(TimeDate[1]);
temp.concat(":") ;
temp.concat(TimeDate[0]);
return(temp);
Any ideas? Thanks
