vielen Dank für die Antwort
postmaster-ino:
dazu die Lib durchforsten.
habe ich bereits
finde aber in den zwei Beispielen keinen Hinweis
hier mal das Originalsketch:
// CONNECTIONS:
// DS1302 CLK/SCLK --> 5
// DS1302 DAT/IO --> 4
// DS1302 RST/CE --> 2
// DS1302 VCC --> 3.3v - 5v
// DS1302 GND --> GND
#include <ThreeWire.h>
#include <RtcDS1302.h>
ThreeWire myWire(A4,A5,A3); // IO, SCLK, CE
RtcDS1302<ThreeWire> Rtc(myWire);
#define countof(a) (sizeof(a) / sizeof(a[0]))
const char data[] = "what time is it";
void setup ()
Serial.begin(57600);
Serial.print("compiled: ");
Serial.print(__DATE__);
Serial.println(__TIME__);
Rtc.Begin();
RtcDateTime compiled = RtcDateTime(__DATE__, __TIME__);
printDateTime(compiled);
if (Rtc.GetIsWriteProtected())
Serial.println("RTC was write protected, enabling writing now");
Rtc.SetIsWriteProtected(false);
if (!Rtc.GetIsRunning())
Serial.println("RTC was not actively running, starting now");
Rtc.SetIsRunning(true);
RtcDateTime now = Rtc.GetDateTime();
if (now < compiled)
Serial.println("RTC is older than compile time! (Updating DateTime)");
Rtc.SetDateTime(compiled);
/* comment out on a second run to see that the info is stored long term */
// Store something in memory on the RTC
uint8_t count = sizeof(data);
uint8_t written = Rtc.SetMemory((const uint8_t*)data, count); // this includes a null terminator for the string
if (written != count)
Serial.print("something didn't match, count = ");
Serial.print(count, DEC);
Serial.print(", written = ");
Serial.print(written, DEC);
/* end of comment out section */
void loop ()
printDateTime(now);
Serial.println(" +");
delay(5000);
// read data
uint8_t buff[20];
const uint8_t count = sizeof(buff);
// get our data
uint8_t gotten = Rtc.GetMemory(buff, count);
if (gotten != count)
Serial.print(", gotten = ");
Serial.print(gotten, DEC);
Serial.print("data read (");
Serial.print(gotten);
Serial.print(") = \"");
// print the string, but terminate if we get a null
for (uint8_t ch = 0; ch < gotten && buff[ch]; ch++)
Serial.print((char)buff[ch]);
Serial.println("\"");
delay(5000);
void printDateTime(const RtcDateTime& dt)
char datestring[20];
snprintf_P(datestring,
countof(datestring),
PSTR("%02u/%02u/%04u %02u:%02u:%02u"),
dt.Month(),
dt.Day(),
dt.Year(),
dt.Hour(),
dt.Minute(),
dt.Second() );
Serial.print(datestring);
und hier noch die Keyword's:
# Syntax Coloring Map RTC
# Datatypes (KEYWORD1)
ThreeWire KEYWORD1
RtcDS1302 KEYWORD1
RtcDS1307 KEYWORD1
DS3234AlarmOne KEYWORD1
DS3234AlarmTwo KEYWORD1
RtcDS3234 KEYWORD1
DS3231AlarmOne KEYWORD1
DS3231AlarmTwo KEYWORD1
RtcDS3231 KEYWORD1
EepromAt24c32 KEYWORD1
RtcTemperature KEYWORD1
RtcDateTime KEYWORD1
DayOfWeek KEYWORD1
# Methods and Functions (KEYWORD2)
Begin KEYWORD2
IsDateTimeValid KEYWORD2
GetIsRunning KEYWORD2
SetIsRunning KEYWORD2
GetIsWriteProtected KEYWORD2
SetIsWriteProtected KEYWORD2
SetDateTime KEYWORD2
GetDateTime KEYWORD2
GetTemperature KEYWORD2
Enable32kHzPin KEYWORD2
SetSquareWavePin KEYWORD2
SetSquareWavePinClockFrequency KEYWORD2
SetAlarmOne KEYWORD2
SetAlarmTwo KEYWORD2
GetAlarmOne KEYWORD2
GetAlarmTwo KEYWORD2
LatchAlarmsTriggeredFlags KEYWORD2
ForceTemperatureCompensationUpdate KEYWORD2
SetTemperatureCompensationRate KEYWORD2
GetTemperatureCompensationRate KEYWORD2
GetAgingOffset KEYWORD2
SetAgingOffset KEYWORD2
GetMemory KEYWORD2
SetMemory KEYWORD2
GetTrickleChargeSettings KEYWORD2
SetTrickleChargeSettings KEYWORD2
AsFloatDegC KEYWORD2
AsFloatDegF KEYWORD2
AsCentiDegC KEYWORD2
Print KEYWORD2
Year KEYWORD2
Month KEYWORD2
Day KEYWORD2
Hour KEYWORD2
Minute KEYWORD2
Second KEYWORD2
DayOfWeek KEYWORD2
TotalSeconds KEYWORD2
DayOf KEYWORD2
ControlFlags KEYWORD2
# Constants (LITERAL1)
DS3231SquareWaveClock_1Hz LITERAL1
DS3231SquareWaveClock_1kHz LITERAL1
DS3231SquareWaveClock_4kHz LITERAL1
DS3231SquareWaveClock_8kHz LITERAL1
DS3231SquareWavePin_ModeNone LITERAL1
DS3231SquareWavePin_ModeBatteryBackup LITERAL1
DS3231SquareWavePin_ModeClock LITERAL1
DS3231SquareWavePin_ModeAlarmOne LITERAL1
DS3231SquareWavePin_ModeAlarmTwo LITERAL1
DS3231SquareWavePin_ModeAlarmBoth LITERAL1
DS3231AlarmOneControl_HoursMinutesSecondsDayOfMonthMatch LITERAL1
DS3231AlarmOneControl_OncePerSecond LITERAL1
DS3231AlarmOneControl_SecondsMatch LITERAL1
DS3231AlarmOneControl_MinutesSecondsMatch LITERAL1
DS3231AlarmOneControl_HoursMinutesSecondsMatch LITERAL1
DS3231AlarmOneControl_HoursMinutesSecondsDayOfWeekMatch LITERAL1
DS3231AlarmTwoControl_HoursMinutesDayOfMonthMatch LITERAL1
DS3231AlarmTwoControl_OncePerMinute LITERAL1
DS3231AlarmTwoControl_MinutesMatch LITERAL1
DS3231AlarmTwoControl_HoursMinutesMatch LITERAL1
DS3231AlarmTwoControl_HoursMinutesDayOfWeekMatch LITERAL1
DS3231AlarmFlag_Alarm1 LITERAL1
DS3231AlarmFlag_Alarm2 LITERAL1
DS3231AlarmFlag_AlarmBoth LITERAL1
DS1302RamSize LITERAL1
DS1302Tcr_Disabled LITERAL1
DS1302TcrResistor_2KOhm LITERAL1
DS1302TcrResistor_4KOhm LITERAL1
DS1302TcrResistor_8KOhm LITERAL1
DS1302TcrDiodes_One LITERAL1
DS1302TcrDiodes_Two LITERAL1
DS1302TcrStatus_Enabled LITERAL1
DS1302TcrStatus_Disabled LITERAL1
DS1307SquareWaveOut_1Hz LITERAL1
DS1307SquareWaveOut_4kHz LITERAL1
DS1307SquareWaveOut_8kHz LITERAL1
DS1307SquareWaveOut_32kHz LITERAL1
DS1307SquareWaveOut_High LITERAL1
DS1307SquareWaveOut_Low LITERAL1
DS3234SquareWaveClock_1Hz LITERAL1
DS3234SquareWaveClock_1kHz LITERAL1
DS3234SquareWaveClock_4kHz LITERAL1
DS3234SquareWaveClock_8kHz LITERAL1
DS3234SquareWavePin_ModeNone LITERAL1
DS3234SquareWavePin_ModeBatteryBackup LITERAL1
DS3234SquareWavePin_ModeClock LITERAL1
DS3234SquareWavePin_ModeAlarmOne LITERAL1
DS3234SquareWavePin_ModeAlarmTwo LITERAL1
DS3234SquareWavePin_ModeAlarmBoth LITERAL1
DS3234AlarmOneControl_HoursMinutesSecondsDayOfMonthMatch LITERAL1
DS3234AlarmOneControl_OncePerSecond LITERAL1
DS3234AlarmOneControl_SecondsMatch LITERAL1
DS3234AlarmOneControl_MinutesSecondsMatch LITERAL1
DS3234AlarmOneControl_HoursMinutesSecondsMatch LITERAL1
DS3234AlarmOneControl_HoursMinutesSecondsDayOfWeekMatch LITERAL1
DS3234AlarmTwoControl_HoursMinutesDayOfMonthMatch LITERAL1
DS3234AlarmTwoControl_OncePerMinute LITERAL1
DS3234AlarmTwoControl_MinutesMatch LITERAL1
DS3234AlarmTwoControl_HoursMinutesMatch LITERAL1
DS3234AlarmTwoControl_HoursMinutesDayOfWeekMatch LITERAL1
DS3234AlarmFlag_Alarm1 LITERAL1
DS3234AlarmFlag_Alarm2 LITERAL1
DS3234AlarmFlag_AlarmBoth LITERAL1
DS3234TempCompensationRate_64Seconds LITERAL1
DS3234TempCompensationRate_128Seconds LITERAL1
DS3234TempCompensationRate_256Seconds LITERAL1
DS3234TempCompensationRate_512Seconds LITERAL1
DayOfWeek_Sunday LITERAL1
DayOfWeek_Monday LITERAL1
DayOfWeek_Tuesday LITERAL1
DayOfWeek_Wednesday LITERAL1
DayOfWeek_Thursday LITERAL1
DayOfWeek_Friday LITERAL1
DayOfWeek_Saturday LITERAL1
habe im Setup folgende Zeile Eingefügt:
Rtc.SetDateTime(19, 1, 8, 14, 52, 0);
fehlt aber noch was oder ist so nicht richtig
erhalte folgende Fehlermeldung
C:\Program Files\Arduino\Scetchbook\4x7Seg_WS2812B\4x7Seg_WS2812B.ino: In function 'void setup()':
4x7Seg_WS2812B:20: error: no matching function for call to 'RtcDS1302::SetDateTime(int, int, int, int, int, int)'
Rtc.SetDateTime(19, 1, 7, 15, 52, 0);
