I have a sketch that fails validation with a raft of errors relating to RTC8563_Class.h. An example is:
Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:20:10: error: 'int8_t' in namespace 'std' does not name a type
20 | std::int8_t hours;
(I will provide the entire list of errors at the end.)
I am running IDE 1.8.19 which I think is the latest version that the Pi can support. The same sketch does not throw these errors when compiled on 1.8.18 running on a Windows machine.
I'm presuming it's something to do with ARM vs Intel? has anyone come across anything similar? I've been to the repo for the M5timer library and tried various versions of the RTC8563_Class.h file but I'll be frank, I'm pretty out of my depth.
It seems a very fundamental error not to be widely reported (ie that the M5 Timer library isn't compatible with Arduino IDE on Pi) so that makes me think it's something to do with my setup.
Full error list:
Arduino: 1.8.19 (Linux), Board: "M5TimerCAM, Enabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 1500000, Core 1, Core 1, None, Disabled"
In file included from /home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/Power_Class.h:11,
from /home/dr-robert-69/Arduino/libraries/Timer-CAM/src/M5TimerCAM.h:4,
from /home/dr-robert-69/Downloads/M5TimerCAM_webserver_connection_test_Jan_24_tinker/M5TimerCAM_webserver_connection_test_Jan_24_tinker.ino:1:
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:20:10: error: 'int8_t' in namespace 'std' does not name a type
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:21:10: error: 'int8_t' in namespace 'std' does not name a type
21 | std::int8_t minutes;
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:22:10: error: 'int8_t' in namespace 'std' does not name a type
22 | std::int8_t seconds;
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:24:27: error: expected ')' before 'hours_'
24 | rtc_time_t(std::int8_t hours_ = -1, std::int8_t minutes_ = -1,
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:26:24: error: expected unqualified-id before ',' token
26 | : hours{hours_}, minutes{minutes_}, seconds{seconds_} {
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:26:43: error: expected unqualified-id before ',' token
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:26:63: error: expected unqualified-id before '{' token
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h: In constructor 'rtc_time_t::rtc_time_t(const tm&)':
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:30:11: error: class 'rtc_time_t' does not have any field named 'hours'
30 | : hours{(int8_t)t.tm_hour},
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:31:11: error: class 'rtc_time_t' does not have any field named 'minutes'
31 | minutes{(int8_t)t.tm_min},
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:32:11: error: class 'rtc_time_t' does not have any field named 'seconds'
32 | seconds{(int8_t)t.tm_sec} {
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h: At global scope:
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:38:10: error: 'int16_t' in namespace 'std' does not name a type
38 | std::int16_t year;
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:41:10: error: 'int8_t' in namespace 'std' does not name a type
41 | std::int8_t month;
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:44:10: error: 'int8_t' in namespace 'std' does not name a type
44 | std::int8_t date;
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:47:10: error: 'int8_t' in namespace 'std' does not name a type
47 | std::int8_t weekDay;
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:49:28: error: expected ')' before 'year_'
49 | rtc_date_t(std::int16_t year_ = 2000, std::int8_t month_ = 1,
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:51:22: error: expected unqualified-id before ',' token
51 | : year{year_}, month{month_}, date{date_}, weekDay{weekDay_} {
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:51:37: error: expected unqualified-id before ',' token
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:51:50: error: expected unqualified-id before ',' token
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:51:70: error: expected unqualified-id before '{' token
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h: In constructor 'rtc_date_t::rtc_date_t(const tm&)':
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:55:11: error: class 'rtc_date_t' does not have any field named 'year'
55 | : year{(int16_t)(t.tm_year + 1900)},
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:56:11: error: class 'rtc_date_t' does not have any field named 'month'
56 | month{(int8_t)(t.tm_mon + 1)},
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:57:11: error: class 'rtc_date_t' does not have any field named 'date'
57 | date{(int8_t)t.tm_mday},
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:58:11: error: class 'rtc_date_t' does not have any field named 'weekDay'
58 | weekDay{(int8_t)t.tm_wday} {
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:79:27: error: 'uint8_t' in namespace 'std' does not name a type
79 | static constexpr std::uint8_t DEFAULT_ADDRESS = 0x51;
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h: In member function 'rtc_time_t RTC8563_Class::getTime()':
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:135:20: error: no matching function for call to 'rtc_time_t::rtc_time_t()'
135 | rtc_time_t time;
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:29:5: note: candidate: 'rtc_time_t::rtc_time_t(const tm&)'
29 | rtc_time_t(const tm& t)
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:29:5: note: candidate expects 1 argument, 0 provided
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:19:32: note: candidate: 'constexpr rtc_time_t::rtc_time_t(const rtc_time_t&)'
19 | struct __attribute__((packed)) rtc_time_t {
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:19:32: note: candidate expects 1 argument, 0 provided
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:19:32: note: candidate: 'constexpr rtc_time_t::rtc_time_t(rtc_time_t&&)'
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h: In member function 'rtc_date_t RTC8563_Class::getDate()':
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:141:20: error: no matching function for call to 'rtc_date_t::rtc_date_t()'
141 | rtc_date_t date;
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:54:5: note: candidate: 'rtc_date_t::rtc_date_t(const tm&)'
54 | rtc_date_t(const tm& t)
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:54:5: note: candidate expects 1 argument, 0 provided
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:36:32: note: candidate: 'constexpr rtc_date_t::rtc_date_t(const rtc_date_t&)'
36 | struct __attribute__((packed)) rtc_date_t {
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:36:32: note: candidate expects 1 argument, 0 provided
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:36:32: note: candidate: 'constexpr rtc_date_t::rtc_date_t(rtc_date_t&&)'
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h: In member function 'rtc_datetime_t RTC8563_Class::getDateTime()':
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:147:24: error: use of deleted function 'rtc_datetime_t::rtc_datetime_t()'
147 | rtc_datetime_t res;
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:65:5: note: 'rtc_datetime_t::rtc_datetime_t()' is implicitly deleted because the default definition would be ill-formed:
65 | rtc_datetime_t() = default;
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:65:5: error: no matching function for call to 'rtc_date_t::rtc_date_t()'
/home/dr-robert-69/Arduino/libraries/Timer-CAM/src/./utility/RTC8563_Class.h:65:5: error: no matching function for call to 'rtc_time_t::rtc_time_t()'
Multiple libraries were found for "WiFi.h"
Used: /home/dr-robert-69/.arduino15/packages/esp32/hardware/esp32/3.1.0/libraries/WiFi
Not used: /home/dr-robert-69/.local/share/arduino-1.8.19/libraries/WiFi
exit status 1
Error compiling for board M5TimerCAM.
option enabled in File -> Preferences.
