RTC_DATA_ATTR and IRAM_ATTR flagged as problems
Variables declared as RTC_DATA_ATTR and code declared with IRAM_ATTR so that the compiled code will be placed in internal RAM rather than flash are flagged as problems.
The code seems to compile and run OK though so this is probably an enhancement if not already reported.
I'm compiling the code for an ESP32 using a Mac running Big Sur version 11.2.3
There is a related report here:
Even though that's for autocomplete, the "problems" and autocomplete are both handled by the Arduino Language Server.
This one might actually be a more informative bug report:
Arduino Language Server is actually only handling the translation from the Arduino programming language of sketches to C++. Once it's in C++, it can be handled by the industry standard clangd language server. clangd can only do its job properly when it has an understanding of the architecture of the microcontroller the code is written for. Fortunately, it does have this for some of the common microcontrollers, but it seems to be lacking for others.
My experience with language servers in general (not specific to the Arduino language server) is that they periodically give incorrect results. You sort of have to have an intuition for when to ignore the red squiggly line. I'm sure more advanced users like yourself will have that, but I do fear that it could cause a lot of confusion for some beginners to see this sort of thing. My preference would be for the language server to be completely disabled by default, but I'm not sure that will happen. They did just make the default setting of the autocomplete functionality disabled so at least there is some progress in that direction.
I forgot to mention that you can troubleshoot this by checking the language server logs.
You can enable them by doing this:
Select Arduino IDE > Preferences (File > Preferences for users of other operating systems) from the menu.
Check the box next to "Enable language server logging".
Click the "OK" button.
Now all the output from the language server will be saved to some .log files in the sketch you have open in Arduino IDE 2.x. You can open that sketch folder, then open the .log files in a text editor and see if you spot anything that looks suspicious.
For example, while I was preparing the bug report for the "megaAVR" architecture issue, I found this in inols-clangd-err.log:
V[12:54:19.163] Ignored diagnostic. unknown target CPU 'atmega4809'
V[12:54:19.163] Ignored diagnostic. valid target CPU values are: avr1, avr2, avr25, avr3, avr31, avr35, avr4, avr5, avr51, avr6, avrxmega1, avrxmega2, avrxmega3, avrxmega4, avrxmega5, avrxmega6, avrxmega7, avrtiny, at90s1200, attiny11, attiny12, attiny15, attiny28, at90s2313, at90s2323, at90s2333, at90s2343, attiny22, attiny26, at86rf401, at90s4414, at90s4433, at90s4434, at90s8515, at90c8534, at90s8535, ata5272, attiny13, attiny13a, attiny2313, attiny2313a, attiny24, attiny24a, attiny4313, attiny44, attiny44a, attiny84, attiny84a, attiny25, attiny45, attiny85, attiny261, attiny261a, attiny441, attiny461, attiny461a, attiny841, attiny861, attiny861a, attiny87, attiny43u, attiny48, attiny88, attiny828, at43usb355, at76c711, atmega103, at43usb320, attiny167, at90usb82, at90usb162, ata5505, atmega8u2, atmega16u2, atmega32u2, attiny1634, atmega8, ata6289, atmega8a, ata6285, ata6286, atmega48, atmega48a, atmega48pa, atmega48pb, atmega48p, atmega88, atmega88a, atmega88p, atmega88pa, atmega88pb, atmega8515, atmega8535, atmega8hva, at90pwm1, at90pwm2, at90pwm2b, at90pwm3, at90pwm3b, at90pwm81, ata5790, ata5795, atmega16, atmega16a, atmega161, atmega162, atmega163, atmega164a, atmega164p, atmega164pa, atmega165, atmega165a, atmega165p, atmega165pa, atmega168, atmega168a, atmega168p, atmega168pa, atmega168pb, atmega169, atmega169a, atmega169p, atmega169pa, atmega32, atmega32a, atmega323, atmega324a, atmega324p, atmega324pa, atmega324pb, atmega325, atmega325a, atmega325p, atmega325pa, atmega3250, atmega3250a, atmega3250p, atmega3250pa, atmega328, atmega328p, atmega328pb, atmega329, atmega329a, atmega329p, atmega329pa, atmega3290, atmega3290a, atmega3290p, atmega3290pa, atmega406, atmega64, atmega64a, atmega640, atmega644, atmega644a, atmega644p, atmega644pa, atmega645, atmega645a, atmega645p, atmega649, atmega649a, atmega649p, atmega6450, atmega6450a, atmega6450p, atmega6490, atmega6490a, atmega6490p, atmega64rfr2, atmega644rfr2, atmega16hva, atmega16hva2, atmega16hvb, atmega16hvbrevb, atmega32hvb, atmega32hvbrevb, atmega64hve, at90can32, at90can64, at90pwm161, at90pwm216, at90pwm316, atmega32c1, atmega64c1, atmega16m1, atmega32m1, atmega64m1, atmega16u4, atmega32u4, atmega32u6, at90usb646, at90usb647, at90scr100, at94k, m3000, atmega128, atmega128a, atmega1280, atmega1281, atmega1284, atmega1284p, atmega128rfa1, atmega128rfr2, atmega1284rfr2, at90can128, at90usb1286, at90usb1287, atmega2560, atmega2561, atmega256rfr2, atmega2564rfr2, atxmega16a4, atxmega16a4u, atxmega16c4, atxmega16d4, atxmega32a4, atxmega32a4u, atxmega32c4, atxmega32d4, atxmega32e5, atxmega16e5, atxmega8e5, atxmega32x1, atxmega64a3, atxmega64a3u, atxmega64a4u, atxmega64b1, atxmega64b3, atxmega64c3, atxmega64d3, atxmega64d4, atxmega64a1, atxmega64a1u, atxmega128a3, atxmega128a3u, atxmega128b1, atxmega128b3, atxmega128c3, atxmega128d3, atxmega128d4, atxmega192a3, atxmega192a3u, atxmega192c3, atxmega192d3, atxmega256a3, atxmega256a3u, atxmega256a3b, atxmega256a3bu, atxmega256c3, atxmega256d3, atxmega384c3, atxmega384d3, atxmega128a1, atxmega128a1u, atxmega128a4u, attiny4, attiny5, attiny9, attiny10, attiny20, attiny40, attiny102, attiny104
E[12:54:19.163] Indexing C:\Users\per\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino\WInterrupts.cpp failed: Couldn't build compiler instance
Thanks for your prompt reply, pert.
I hadn’t considered those issues as the title didn’t seem to fit my issue.
