RTClib problems
Hey, I'm trying to use the RTClib, as I was following a short tutorial on the Adafruit website: http://learn.adafruit.com/ds1307-real-time-clock-breakout-board-kit/overview
But...when I try to compile anything with the library this is all I get...: \Arduino\libraries\RTClibmaster2/RTClib.h:7: error: expected )' before 't' \Arduino\libraries\RTClibmaster2/RTClib.h:8: error: expected)' before 'year' \Arduino\libraries\RTClibmaster2/RTClib.h:11: error: 'uint16_t' does not name a type \Arduino\libraries\RTClibmaster2/RTClib.h:12: error: 'uint8_t' does not name a type \Arduino\libraries\RTClibmaster2/RTClib.h:13: error: 'uint8_t' does not name a type \Arduino\libraries\RTClibmaster2/RTClib.h:14: error: 'uint8_t' does not name a type \Arduino\libraries\RTClibmaster2/RTClib.h:15: error: 'uint8_t' does not name a type \Arduino\libraries\RTClibmaster2/RTClib.h:16: error: 'uint8_t' does not name a type \Arduino\libraries\RTClibmaster2/RTClib.h:17: error: 'uint8_t' does not name a type \Arduino\libraries\RTClibmaster2/RTClib.h:22: error: 'uint32_t' does not name a type \Arduino\libraries\RTClibmaster2/RTClib.h:25: error: 'uint8_t' does not name a type \Arduino\libraries\RTClibmaster2/RTClib.h:31: error: 'uint8_t' does not name a type \Arduino\libraries\RTClibmaster2/RTClib.h:33: error: 'uint8_t' does not name a type
Any help?
Did you look at: http://learn.adafruit.com/arduino-tips-tricks-and-techniques/arduino-libraries
LarryD:
Did you look at:
Yup
Would you attach your sketch?
#include <RTClib.h>
void setup() {}
void loop() {}
No need for extras when testing the library.
So you placed the library here?
C:\Users....Your Stuff...\Documents\Arduino\libraries\RTClib
LarryD: So you placed the library here?
Yes
Try:
#include <Wire.h>
#include "RTClib.h"
void setup() {}
void loop() {}
LarryD:
Try:
#include <Wire.h>
#include “RTClib.h”
void setup() {}
void loop() {}
I am retarded and overlooked everything in this simple attempt, Wire is indeed required, thanks for pointing that out.
I am retarded
No you aren't!
LarryD:
I am retarded
No you aren't!
Well, if I had looked deeper at the example that I posted originally, under the "Understanding the Code" section, they include both the Wire and the RTC libraries, not to mention the main description at one part was "Communicating over I2C" or something with regards to the RTC.
lol
