I have reduced the code down to the minimum to try and work out what is wrong but it always fails on "Compilation error: expected primary-expression before '==' token"
Thanks for your suggestion. Actually I have tried all combinations of brackets.
Your version fails with "Compilation error: expected primary-expression before ')' token" It seems to me that it's the "primary-expression" which is the problem.
Thank you so much all. That was the problem. I had #define LOG_INTERVAL
instead of #define LOG_INTERVAL 15
Thanks again. I just couldn't see the problem which should have hit me in the face!
Not sure if will work correctly, tho. The condition will be true for a full 60 seconds, which could result in multiple updates to the log, unless you use millis() or delay() ( ) to avoid that.
You are right of course. I had cut down the sample of code as I was focussed on why the if wasn't working. My stupid mistake!
This is how the code is going to be structured.
if (currentTime.getMinutes() % LOG_INTERVAL == 0) {
if (!logged) {
//Log data
//logFile.print(currentTime);
//logFile.print(",");
//logFile.println(Temperature);
//logFile.flush();
Serial.print(currentTime);
Serial.print(",");
Serial.println(Temperature);
logged = true;
logged = false;
