RTD 3-wire sensor connection problem
Hi, I recently bought this sensor: Rtd pt100 temperature sensors 1/2 inch npt threads with detachable connector Sale - Banggood.com-arrival notice-arrival notice
But I can't get to figure out how to connect it and make it work.
If I measure the resistance with a multimeter and I get 0 between the blue leads but nothing between the red and any of the others. By nothing I mean like if they weren't connected at all.
Does anyone know what else I can try? I'm starting thinking it either require higher voltage or it's even broken..
The resistance between wires at one end should be zero ohms, that between one of those wires are the other end if the sensor about 100ohms.
You need an amplifier/shield to get a big enough signal for an Arduino to see .
If you put a voltage across the sensor , eg 5v , you will have burnt it out .
Here's one breakout board to read RTDs with Arduino.
That makes sense now..
Thank you so much for your help!!
