Rubiks Cube solver HELP!
I want to build a rubik's cube solver, and I want to give the arduino the commands from my computer what side to turn, But I never worked with Arduino before, and I don't know how many in/output I should use, and even what Arduino is the best for doing so.
So far I discovered that The minimal sides to turn is 3 to solve the complete cube, Left Front and Right, and you need to be able to clamp the side individually
My Throughts of outputs/inputs;
LeftClamp
LeftLose
LeftClockWise
LeftCounterClockWise
FrontClamp
FrontLose
FrontClockWise
FrontCounterClockWise
RightClamp
RightLose
RightClockWise
RightCounterClockWise
Anyone that can help me figuring out what is the best?
The Setup of the cube;
Sorry for any grammar mistakes, I'm Dutch
While you're turning each face the opposite end will need to be held, so the operations will be something like:
Hold back 2 layers // Do this first, otherwise the cube will fall :slight_smile:
Release sides
Hold front layer
Turn (either left or right)
Hold rightmost 2 layers. // Do this first, otherwise the cube will fall :slight_smile:
Release back 2 layers
Hold leftmost layer
Turn
Etc., etc.
Some other guy did this on here recently. He had a cool video of the finished machine working. Google should find it for you.
...R
