run a dc motor for a specific time
Helo,
I am trying to set a dc motor to work for a fixed amount of time. for example if i will press left to work for a minnut and after to stop. if i will press right, to work for a minut and after to stop. What to i need to change on this code?:
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
// Replace with your network credentials
const char* ssid = "******";
const char* password = "******";
ESP8266WebServer server(80);   //instantiate server at port 80 (http port)
String page = "http://*********"; //For the Web Server
String page2="";  //For updating Status of motor 1
String page3="";  //For updating status of motor 2
void setup(void)
  //the HTML of the web page
  page = "<center><h1>Motor Control Web Server</h1><body><p><a href=\"Forward\"><button>Forward</button></a><p><a href=\"Backward\"><button>Backward</button></a></p><p><a href =\"Left\"><button>Left</button></a>&nbsp;<a href=\"Stop\"><button>Stop</button></a><a href=\"Right\"><button>Right</button></a></p></body></center>";
  pinMode(D7,OUTPUT);    // inputs for motor 1
  pinMode(D8,OUTPUT);
  pinMode(LED_BUILTIN,OUTPUT);  // For status of WiFi connection
  WiFi.begin(ssid, password); //begin WiFi connection
  Serial.println("");
  // Wait for connection
    Serial.print(".");
  digitalWrite(LED_BUILTIN,HIGH);     // when connected turns high
  Serial.println("");
  Serial.print("Connected to ");
  Serial.println(ssid);
  Serial.print("IP address: ");
  Serial.println(WiFi.localIP());   //provides IP address
   server.on("/", [](){
    server.send(200, "text/html", page+page2);
  server.on("/Left",Left);
  server.on("/Right",Right);
  server.on("/Stop",[](){
// turns all the motor input pins low
   page2="<center><p> motor 1 Status : Off</p></center>";
   page3="<center><p> motor 2 Status : off</p></center>";
   server.send(200,"text/html",page+page2+page3);
    digitalWrite(D5,LOW);
    digitalWrite(D6,LOW);
    digitalWrite(D7,LOW);
    digitalWrite(D8,LOW);
    delay(200);
  server.begin();
  Serial.println("Web server started!");
void loop(void)
     server.handleClient();
  void Left()
    page3="<center><p> motor 2 Status : Left</p></center>";
    digitalWrite(D7,HIGH);
    delay(200);
  void Right()
    page3="<center><p> motor 2 Status : Right</p></center>";
    digitalWrite(D8,HIGH);
    delay(200);
Please read how to use this forum
Found as a sticky post at the top of every forum
Pay attention to #7 code tags
Then come back and fix you post.
Bottom right of your post is modify
What does this code do, and how is it different from what it should do?
If you press the right button during the minute of running left (and vice versa), what should happen?
