Run a remote PHP script from an Ethernet-Shield Arduino
I have a PHP script on an external web server. If I view www.example.com/test/myphp.php in my browser, the server runs the script just fine. Now I want the server to run the script when my Arduino says so, instead of when I view it in my browser. I want the Arduino to remotely trigger the script to run.
please reply
You probably can use client code similar to the below code that sends a GET request.
//zoomkat 3-1-13
//simple client checkip test
//for use with IDE 1.0.1 or later
//with DNS, DHCP, and Host
//open serial monitor and send an e to test
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
char serverName[] = "checkip.dyndns.com"; // test web page server
EthernetClient client;
void setup(){
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    while(true);
  Serial.println("Better client ip test 3/1/13"); // so I can keep track of what is loaded
  Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
  // check for serial input
  if (Serial.available() > 0) //if something in serial buffer
    byte inChar; // sets inChar as a byte
    inChar = Serial.read(); //gets byte from buffer
    if(inChar == 'e') // checks to see byte is an e
      sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
  if (client.connect(serverName, 80)) {  //starts client connection, checks for connection
    Serial.println("connected");
    client.println("GET / HTTP/1.0"); //download text
    client.println("Host: checkip.dyndns.com");
    client.println(); //end of get request
  else {
    Serial.println("connection failed"); //error message if no client connect
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    char c = client.read(); //gets byte from ethernet buffer
    Serial.print(c); //prints byte to serial monitor
  Serial.println("disconnecting.");
  Serial.println("==================");
  client.stop(); //stop client
I have on website www.xxxxx.com/send.php script to send email to user. I want when i run program in arduino to run a scirpt on server. I dont know how to do it with GET request. Can you please send me code to execute this script on server.
i have solved the problem :slight_smile:
Here is my code
#include <SPI.h>
char server[] = "www.xxxxx.com";
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192,168,0,177);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
  // start the Ethernet connection:
    Serial.println("SERIAL: Failed to configure Ethernet using DHCP");
  // give the Ethernet shield a second to initialize:
  Serial.println("SERIAL: connecting...");
  // if you get a connection, report back via serial:
  if (client.connect(server, 80)) {
     client.print("GET /send.php");
     client.println(" HTTP/1.1");
     client.println("Host: www.xxxxx.com");
     client.println("User-Agent: Arduino");
     client.println("Accept: text/html");
     client.println("Connection: close");
     client.println();
  else {
    // if you didn't get a connection to the server:
    Serial.println("SERIAL: connection failed");
  // if there are incoming bytes available, print them
  if (client.available()) {
    Serial.print(c);
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    client.stop();
    // do nothing forevermore:
    while(true);
