Run function from another function?
Hi, I want to be able to run a function from another function. I would like to be able to do something like this.
void setup(){
void loop(){
runFunction(someStuff);
void runFunction(void Function){
Function();
void someStuff(){
Serial.println("Hi");
How would I go about doing this? Sorry if this is a really nooby question...
Google "C function pointers"
Make the function argument either a reference or pointer.
Reference:void runFunction(void (&Function)())
Pointer:
void runFunction(void (*Function)())
  (*Function)();
The reference way requires fewer changes.
johnwasser:
Pointer:
 (*Function)();
The pointer way can be written like this:
  Function();
There's no need to dereference a function pointer before calling it.
Wow thanks for the help. Much more simple than I expected. One more thing. As Im trying to use this for a library, Would I need to (and how) assign the function to another variable again in the class?
class NBDelay
 public:
 NBDelay(void (&Function)(), int time);
 void check();
 private:
 int pMillis(), int Time;
 void (&Function2)() = Function;
Not sure if the void (&Function2)() = Function; part would work or not...
Not sure if the
Code: [Select]
It will not. Re-read the first reply. The word pointer was in there for a reason.
If you want a function to store the address of the other function to be called later, definitely use a pointer.
class NBDelay
 public:
 NBDelay(void (*Function)(), int time);
 void check();
 private:
 int pMillis(), Time;
 void (*Function2)();
Cool. Thanks for the help.
