Hi, I have a question, I made a code for a Daft Punk helmet with WS8212 RGB leds, and i want to use a keypad 4x4 and a i2c 16x2 lcd display to control the different effects for the helmet, i have all the effect functions ready but i want to select a function and run it in loop, but i wanna still use the keypad to move trough the menu when any effects is running to change it o stop it, also i have the menu ready and it's working with the LCD, thanks for any help. i'm a begginer and Excuse my bad english.
#include <Keypad.h>
#include <Wire.h>
#include <FastLED.h>
#define LED_TYPE WS2812B // type of RGB LEDs
#define COLOR_ORDER GRB // sequence of colors in data stream
#define NUM_LEDS 36 // 60 LEDs numbered [0..59]
#define DATA_PIN 11 // LED data pin
#define DATA_PIN2 12 // LED data pin
#define BRIGHTNESS 100 // brightness range [off..on] = [0..255]
CRGB leds[NUM_LEDS];// Define the array of RGB control data for each LED
/////TECLADO////////
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
byte rowPins[ROWS] = {9, 8, 7, 6}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {5, 4, 3, 2}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad numpad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
///////LCD////////////
LiquidCrystal_I2C lcd(0x27,16,2); // set the LCD address to 0x27 for a 16 chars and 2 line display
char key;
int counter=1;
FastLED.addLeds<LED_TYPE, DATA_PIN, COLOR_ORDER>(leds, NUM_LEDS); // initialize library using CRGB LED array
FastLED.addLeds<LED_TYPE, DATA_PIN2, COLOR_ORDER>(leds, NUM_LEDS); // initialize library using CRGB LED array
lcd.init();
lcd.backlight();
menu_1(); //HOMESCREEN
key = numpad.getKey() ;
if (key != 0)
lcd.clear();
if(counter == 3){ menu_3();accion_3();}
if(counter == 2){ menu_2();accion_2();}
if(counter == 1){ menu_1();accion_1();}
/////////////////////Menu_1 //////////////////////////////
void menu_1()
FastLED.setBrightness(250);
lcd.backlight();
lcd.setCursor(0,0);
lcd.print("DAFT PUNK HELMET");
lcd.setCursor(2,1);
lcd.print("CONTINUE #");
/////////////////////Accion 1 //////////////////////////////
void accion_1()
if(key == '#')
lcd.clear();
counter=2;
/////////////////////Menu_2 //////////////////////////////////
void menu_2()
lcd.setCursor(2,0);
lcd.print("LIGHTS");
lcd.setCursor(8,0);
lcd.print("VISOR");
lcd.setCursor(0,1);
lcd.print("ON-1");
lcd.setCursor(6,1);
lcd.print("OFF-2");
lcd.setCursor(13,1);
lcd.print("<-*");
/////////////////////Accion 2 //////////////////////////////
void accion_2(){
if(key == '1') {
lcd.clear();
counter=3;
if(key == '2') cascooff();
if(key == '*') {
lcd.clear();
counter=1;
/////////////////////Menu_3 //////////////////////////////////
void menu_3()
lcd.setCursor(4,0);
lcd.print("EFFECTS");
lcd.setCursor(0,1);
lcd.print("1 2 3 4 5 6");
lcd.print("<-D");
/////////////////////accion_3 //////////////////////////////////
void accion_3(){
if(key == '1') effect1();
if(key == '2') effect2();
if(key == '3') effect3();
if(key == '4') effect4();
if(key == '5') effect5();
if(key == '6') effect6();
if(key == 'D') {
lcd.clear();
counter=2;
/////////////////////EFFECTS//////////////////////////////////
int m=0;
int x=0;
uint32_t color[] = {CRGB::Red, CRGB::Orange, CRGB::Yellow,
CRGB::GreenYellow, CRGB::Green, CRGB::LightSeaGreen,
CRGB::Blue, CRGB::Purple, CRGB::White,};
/////////////////////apagado casco//////////////////////////////////
void cascooff()
fill_solid( &(leds[0]), 35 /*number of leds*/, CRGB::Black);
FastLED.setBrightness(0);
FastLED.show();
lcd.clear();
counter=1;
/////////////////////EFECTO 1//////////////////////////////////
void effect1()
int f=0;
for (f=8;f>=0;f--)
int top=(f*4)+3;
for (m=0;m<=top;m+=4)
unsigned long start = millis()+25;
while(start > millis())
fill_solid( &(leds[m]), 4 /*number of leds*/,color[x]);
FastLED.show();
fill_solid( &(leds[m]), 4 /*number of leds*/, CRGB::Black);
fill_solid( &(leds[0]), m /*number of leds*/,CRGB::Black);
if (x<8)(x++);
else (x=0);
for (f=8;f>=0;f--)
int top=(f*4);
for (m=top;m>=0;m-=4)
fill_solid( &(leds[m]), 4 /*number of leds*/,CRGB::Black);
FastLED.show();
fill_solid( &(leds[m]), 4 /*number of leds*/, color[x]);
FastLED.show();
fill_solid( &(leds[top]), 4 /*number of leds*/,CRGB::Black);
FastLED.show();
if (x<8)(x++);
else (x=0);
/////////////////////EFFECT 2//////////////////////////////////
void effect2()
int f=0;
for (f=8;f>=0;f--){
for (m=0;m<NUM_LEDS;m+=4)
unsigned long start = millis()+50;
while(start > millis()){
fill_solid( &(leds[m]), 4 /*number of leds*/,color[f]);
FastLED.show();}
f--;
fill_solid( &(leds[0]), NUM_LEDS /*number of leds*/, CRGB::Black);
FastLED.show();
f==0;
for (f=0;f<=8;f++){
for (m=36;m>0;m-=4)
fill_solid( &(leds[m-4]), 4 /*number of leds*/,color[f]);
FastLED.show();}
f++;
fill_solid( &(leds[m-4]), 4 /*number of leds*/, CRGB::Black);
FastLED.show();
/////////////////////EFFECT 3//////////////////////////////////
void effect3()
int f=0;
for (f=8;f>=0;f--){
FastLED.show();}
f--;
FastLED.show();
/////////////////////EFFECT 4//////////////////////////////////
void effect4 ()
int f=0;
for (f=0;f<=8;f++){
FastLED.show();}
FastLED.show();
/////////////////////EFFECT 5//////////////////////////////////
void effect5()
unsigned long start = millis()+5000;
uint8_t thishue = millis()*(255-200)/255;
fill_rainbow(leds, NUM_LEDS, thishue, 10);
FastLED.show();
/////////////////////EFFECT 6//////////////////////////////////
void effect6(){
effect1();
effect2();
effect2();
effect2();
effect2();
effect3();
effect3();
effect3();
effect3();
effect3();
effect3();
effect4();
effect5();
