Run OpenWRTYun on other hardware
Hi!
I am very pleased to use the OpenWRTYun with this vibrant community.
I have an old drink router with an openwrt on it.
Is it possible to install OpenWRTYun on it?
The CPU is a MIPS 24KEc V4.12, where on the Yun is MIPS 24Kc V7.4…
cat /proc/cpuinfo
system type		: Ralink RT3350 id:1 rev:2
machine			: D-Link DIR-300 B1
processor		: 0
cpu model		: MIPS 24KEc V4.12
BogoMIPS		: 212.58
wait instruction	: yes
microsecond timers	: yes
tlb_entries		: 32
extra interrupt vector	: yes
hardware watchpoint	: yes, count: 4, address/irw mask: [0x0000, 0x0000, 0x0230, 0x0000]
ASEs implemented	: mips16 dsp
shadow register sets	: 1
kscratch registers	: 0
core			: 0
VCED exceptions		: not available
VCEI exceptions		: not available
HAve you ever tried it?
D-Link DIR-300 B1 Processor RaLink RT288x/RT305x WiSoC Wireless Ralink RT3050F Architecture MIPS24KEc@320Mhz (little-endian) RAM 32 MB Flash Memory 4 MB USB No Card Reader No These devices use the "ramips" target of OpenWRT.
Arduino Yun Processor Atheros AR9331 Architecture MIPS 24Kc V7.4@400MHz (big-endian) RAM 64 MB DDR2 Flash Memory 16 MB USB Type-A 2.0 Host Card Reader Micro-SD only These devices use the "AR71**" target of OpenWRT.
Support Openwrt-Yun is very simple at software point of view ( many thanks for hard work of team);- cross compile bridge software - cpu-mcu-bridge https://github.com/arduino/openwrt-packages-yun/tree/master/arduino
But hardware has some requirement. if I were you, I will port it to new router which could run 10 times faster...
Your router has 4MB of flash memory: now way to fit the yun image on it :) But if you manage to, please share how: I've an old router too.
The killer is no directly USB support, I knew it support hardware mod to add on USB port. Once plugin 16 GB USB flash with U-boot which support USB boot will bring 16 GB rootfs ...
