Run the relay once in loop after buttonpress [solved]
Hello,
Is there another way, for example, to trigger a relay once after you press the button. (The code below doesn't work btw)
What I want it to do is after you press the button, the relay turns on for 5 seconds. After the 5 seconds it turns off and doesn't activate even if the relay is still activated UNTIL you release the button and press it again.
bool fHasLooped = false;
void zaag(){
int switchstate = digitalRead(safety_switch);
  if (switchstate = LOW) {
    if (fHasLooped == false)
      for (int x = 0; x < 1; x++)
        delay(2000);
        digitalWrite(relay, HIGH);
        delay(5000);
        digitalWrite(relay, LOW);
      fHasLooped = false;
  else {
You need to check if the switch has changed state from HIGH to LOW - something like this
static byte switchState = LOW; // assumes LOW when pressed
                // static ensures the value is remembered between iterations of loop()
byte previousSwitchState;
previousSwitchState = switchState;
switchState = digitalRead(switchPin);
if (switchState == LOW and previousSwitchState == HIGH) {
Note that your use of delay()s will make you program unresponsive. The functions delay() and delayMicroseconds() block the Arduino until they complete. Have a look at how millis() is used to manage timing without blocking in Several Things at a Time.
And see Using millis() for timing. A beginners guide if you need more explanation.
...R
Why use a for loop with only 1 step ?
That is because I want to use it multiple times, but only when the button is pressed.
I used this because i thought it was possible to force it to run once after activating. (Just wanted to try it out)
Here is a way to do it using library calls.
#include <mechButton.h>
#define  TRIGGER_PIN 2        // What pin the trigger will be on.
#define  OUT_PIN     13       // What pin we'll toggle high when the trigger goes low.
#define  HOLD_MS     500      // How long we'll hold the output high after being triggered.
mechButton  trigger(TRIGGER_PIN);   // Button debouncer.
timeObj     timer;                  // Our output hold timer.
// Your standard Arduino setup() function.
   pinMode(OUT_PIN,OUTPUT);               // Setup output pin.
   digitalWrite(OUT_PIN,LOW);             // Lets make sure its off.
   trigger.setCallback(triggerAction);    // Set up the function to call when the trigger is clicked.
   timer.setTime(HOLD_MS,false);          // Set the timer, but don't start it yet.
// When you click the button, this function will be called.
void triggerAction(void) {
   if (!trigger.trueFalse()) {      // If the trigger returns false, button has been clicked.
      digitalWrite(OUT_PIN,HIGH);   // So we fire the output pin.
      timer.start();                // And start the timer.
// Your standard Arduino loop() function.
   idle();                       // Give the stuff running behind the scenes time to run.
   if (timer.ding()) {           // If the timer has expired..
      digitalWrite(OUT_PIN,LOW); // Shut down the output.
      timer.reset();             // Reset the timer for next time.
If you would like to try it this way you will need LC_baseTools from your Arduino IDE library manager.
Good luck.
-jim lee
A state machine would seem to fit the bill
enum STATES
  WAITING,
  TIMING
STATES currentState = WAITING;
const byte buttonPin = 27;
const byte relayPin = 26;
byte currentButtonState;
byte previousButtonState;
unsigned long waitStartTime;
unsigned long currentTime;
unsigned long waitPeriod = 5000;
  while (!Serial);
  pinMode(buttonPin, INPUT_PULLUP);
  pinMode(relayPin, OUTPUT);
  digitalWrite(relayPin, HIGH);
  currentTime = millis();
  switch (currentState)
    case WAITING:
      previousButtonState = currentButtonState;
      currentButtonState = digitalRead(buttonPin);
      if (currentButtonState != previousButtonState)  //button state has changed
        if (currentButtonState == LOW)  //button has become pressed
          digitalWrite(relayPin, LOW);
          waitStartTime = currentTime;
          currentState = TIMING;
    case  TIMING:
      if (currentTime - waitStartTime >= waitPeriod)
        Serial.println("time's up");
    case RELEASED_AND_TIMING:
Thanks!
I noticed (line 52)
wasn't in the enum STATES so i added it in.
It works now!
That state was left over from my original idea but is, in fact, not needed. Simply removing it from the sketch completely works
