Run Time error with this code
I compiled this code with no errors but for some reason I get run-time error (the device gets stuck):
// ErrorLog.h
#ifndef ERRORLOG
#define ERRORLOG
#define ERR_BUFF_SIZE 8
#define ERR_DISABLE 0
#define ERR_ENABLE 1
enum {
** ERR_NOIP = 0,**
** ERR_CONNECTION,**
** ERR_NTPsync,**
** ERR_SD,**
** ERR_WEB,**
** ERR_ANALOG,**
** ERR_DIGITAL,**
** ERR_ONE_WIRE**
char ERR_LOG_TXT[ERR_BUFF_SIZE][100] = { "No IP adress", "Ethernet connection Error", "NTP server sync Error", "SD card Error", "Web server Error", "Analog input Error", "Digital Input Error", "One Wire Error" };
typedef struct
** unsigned char status; // enabled/disabled**
** unsigned char counter;**
** unsigned char errorCode;**
** unsigned char trigger;**
} ERR_TYPE;
ERR_TYPE Error[ERR_BUFF_SIZE];
void initERR(void)
** char i;**
** //ENABLE all timers**
** for (i = 0; i < ERR_BUFF_SIZE; i++) {**
Error*.status = ERR_ENABLE;
_ Error
.counter = 0;
Error
.trigger = 0;
Error.errorCode = i;
// Serial<<F(i);_
// Serial<<F(":")<<(ERR_LOG_TXT)<<("- Enable -");
_ }
void ErrorHandler(){
char i;
//_
for (i = 0; i < ERR_BUFF_SIZE; i++){
if (Error_.status && Error.trigger){
// Serial << F("HELLO");
// Serial.print("Logging Error Code#:");
// Serial.println(Error.errorCode);_
// Serial.println(ERR_LOG_TXT);
_ Error.counter++;
//do the logging to SDcards here*
Error*.trigger=false; //reset the trigger*
#endif*
[/b][/quote]
The problem seems to be in void initERR(void) where Error*.status is causing the problem (and any other array calling).*
can anyone help ?
Thank you_
Which Arduino are you using? If an Uno, you are probably running out of SRAM. You are using 800 bytes here.
I'm using Mega
Binary sketch size: 78,554 bytes (of a 258,048 byte maximum)
The Error structure variable is an array, so I would access it like an array.
typedef struct
} ERR_TYPE;
  //ENABLE all timers
    Error[i].status = ERR_ENABLE;
    Error[i].counter = 0;
    Error[i].trigger = 0;
    Error[i].errorCode = i;
   //  Serial<<F(i);
loop()?
setup()?
initERR() is being called from setup{}
ErrorHandler() is being called from loop{}
I commented everything related to this header and left only initERR()
the problem is in "Error*.status = ERR_ENABLE;"*
for example this code dosn't cause problem:
typedef struct
  • unsigned char status; // enabled/disabled*
  • unsigned char counter;*
  • unsigned char errorCode;*
  • unsigned char trigger;*
    } ERR_TYPE;
    ERR_TYPE ErrorOne;
    void initERR()
  • ErrorOne.status = ERR_ENABLE;*
  • ErrorOne.counter = 0;*
  • ErrorOne.trigger = 0;*
Why the italics?
dont know
Well, stop the vague hand-waving, and let's see the source.
In this code, the ErrorOne variable is not an array, just a structure, and you are accessing it correctly.
typedef struct
} ERR_TYPE;
ERR_TYPE ErrorOne;
void initERR()
In this code, the Error variable is an array of structures and you are not accessing it correctly. See reply #3 above.
typedef struct
} ERR_TYPE;
void initERR(void)
  char i;
    Error.status = ERR_ENABLE;
    Error.counter = 0;
    Error.trigger = 0;
I'm sorry - this is the code that causing me problems
typedef struct
ERR_TYPE;
void initERR(void)
char i;
//ENABLE all ErrorLogs
Error*.status = ERR_ENABLE;*
_ Error*.counter = 0;_
_ Error.trigger = 0;
In this case Error is an array pf structures and I'm accessing each one inside the for loop
again - what is the problem ?_
That is correct. You are accessing Error as a structure, not an array of structures. Are you not seeing the correction I suggested in reply #3? Are you not scrolling the code box down to see how to access an array of structures? Here it is:
void initERR(void)
  char i;
SurferTim has the correct answer. But I don't understand how the original code even compiles.
Error is declared as an array of structures. So, when Error is referenced by itself without an array subscript, it is treated as a pointer to the first element of the array. So, with Error being a pointer to a structure, Error.status should be a compile time error, because the proper way to dereference the pointer would be Error->status.
(Of course, this would only ever access the first element of the array, so using the "->" notation is NOT the solution to the OP's problem where he wants to access every array element in the loop. I only bring up this notation as a contrast to the erroneous "."notation of a pointer.)
This code is definitely erroneous:
    Error.counter = 0;
    Error.trigger = 0;
So why does it even compile? It should be a compile time error, and have never made it to a run time error.
The forum has two of almost every smiley, but it doesn't have a confused smiley that's scratching its head or has questions marks... Pity, that would be perfect for this post...
But it does have code tags. . .
Oh I get it now, he he he he
there is i index in Error.Status but the HTML page dosn't show it..
that explains the italic hehhe.. here let me try again uploading my code:
typedef struct
ERR_TYPE;
void initERR(void)
  char i;
As you can see I have i index and still it causes problem
No it doesn't. It must be something else in your sketch. I tried this test code and it works fine. I stored and then displayed the errorCode.
typedef struct
ERR_TYPE;
void initERR(void)
  char i;
void printERR(void)
  char i;
    Serial.println(Error[i].errorCode);
  initERR();
  printERR();
It displayed this
0
1
2
3
4
5
6
7
So the good news is that the code if fine
The bad news is that I have no Idea where is the problem..
YairYakov:
And that's why it's important to use the code tags, and not quote tags or simply placing the code inline.
OK, that explains why it compiled.
You say you think the error is in the initErr() function. Why do you say that?
It's been stated before that it might be an out of memory error (stack colliding with other memory data values.) It could be. This construct seems to be particularly wasteful of precious RAM:
This takes up 800 bytes (8 * 100) but only stores 147 useful bytes. That's about a quarter of your available memory wasted on unused space. A more efficient way of storing it would be:
char* ERR_LOG_TXT[ERR_BUFF_SIZE] = { "No IP adress", "Ethernet connection Error", "NTP server sync Error", "SD card Error", "Web server Error", "Analog input Error", "Digital Input Error", "One Wire Error" };
Note that it was changed from an array of 100 character arrays, to now be an array of character pointers. This means that ERR_LOG_TXT is now an array of 8 pointers, each of which points to a character string. It would seem that adding that extra array of pointers would use even more memory, but it ends up using only 163 bytes to store the same information as opposed to 800. With such a limited memory budget, that saving of 637 bytes can make a difference.
The original code allocated 100 bytes for each string, even though the longest one only needs 26 bytes. You could make that array index smaller than 100, but then you have to remember to make it bigger if you ever put in a longer message, plus you are still wasting memory for all of the strings that are shorter than the longest one.
By adding the array of pointers, each string takes up only as much space as needed; they do not have to be padded out to some arbitrary maximum length. The memory savings is well worth adding the extra array of pointers.
Note that the only thing that needs to change is the declaration. The ERR_LOG_TXT array is still accessed the same as it was before since a pointer to a character is logically the same as a character array.
With the importance of code tags now understood, would you please post the entire sketch in code tags? Perhaps there have been other bits of code that got swallowed up by the forum formatter.
ShapeShifter:
Because I've commented any other calling to this file and left only initERR() and it caused an error
and after I commented initERR() it was fine
ShapeShifter:
You are right, i'll change that
Again here is the whole code - I'm calling these functions from the main code
// ErrorLog.h
#ifndef ERRORLOG
#define ERRORLOG
enum {
  ERR_NOIP = 0,
  ERR_CONNECTION,
  ERR_NTPsync,
  ERR_SD,
  ERR_WEB,
  ERR_ANALOG,
  ERR_DIGITAL,
  ERR_ONE_WIRE
typedef struct
ERR_TYPE;
void initERR(void)
  char i;
  char i;
    if (Error[i].status && Error[i].trigger){
    //  Serial.println(Error[i].errorCode);
   //   Serial.println(ERR_LOG_TXT[i]);
      Error[i].counter++;
      Error[i].trigger=false; //reset the trigger
#endif
This code is not original coded by me and I'm continuing an existing code.
The project contains one *.ino file and some *.h files but no *.c files at all
inside the *.h there are some functions that are being called
Since this is my first project in arduino I wanted to know if this is the common way to code in arduino.
I know from C that there should be *.h for each *.c file and the *.h should contain definitions and function statements and the *.c should have the function itself.
Maybe this causing some problems ?
