running 2 servos at once
hi,
I am wanting to run to servos at once on the one UNO, I have one 6 V power supply to the board and here is my sketch, however I can only get one servo to move not both at the same time ?
thanks
ian
/* Sweep
by BARRAGAN http://barraganstudio.com
This example code is in the public domain.
modified 8 Nov 2013
by Scott Fitzgerald
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0; // variable to store the servo position
myservo.attach(9); // attaches the servo on pin 9 to the servo object
myservo.attach(8); // attaches the servo on pin 9 to the servo object
for(pos = 0; pos <= 20; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for(pos = 20; pos>=89; pos-=1) // goes from 180 degrees to 0 degrees
delay(15);
Did you mean to have two Servo objects attached to two different pins?
If you want to drive two servos from one pin, just wire both signal pins on the servo to the same pin and do a single "attach".
yes i mean two servos at different pins like 8 and 9
thanks
(uncompiled, untested)
#include <Servo.h>
Servo myservo [2];
  myservo[0].attach(9);
  myservo[1].attach(8);
  for(pos = 0; pos <= 20; pos += 1) // goes from 0 degrees to 20 degrees
    myservo[0].write(pos);
    myservo[1].write(pos);
    delay(15);
  // etc, etc
It is true that you can create several servo objects but they need to have different names otherwise when you do
myservo.write(pos);
how will the program know which servo to move ?
