Running 2 servos, stepper and color sensor
I'm currently doing a project that requires me to use 2 servos, a stepper and a color sensor. I currently have 2 Arduino Uno Controller boards but would like to only use one. I have codes for the stepper and servo but they only run on their own and I need them to run simultaneously. The stepper is connected to a power supply module.
Here's my sketch for the stepper:
int pin1 = 10;
int pin2 = 11;
int pin3 = 12;
int pin4 = 13;
boolean dir = false;
pinMode(pin1, OUTPUT);
pinMode(pin2, OUTPUT);
pinMode(pin3, OUTPUT);
pinMode(pin4, OUTPUT);
switch(_step){
case 0:
digitalWrite(pin1, LOW);
digitalWrite(pin2, LOW);
digitalWrite(pin3, LOW);
digitalWrite(pin4, HIGH);
case 1:
digitalWrite(pin3, HIGH);
case 2:
digitalWrite(pin4, LOW);
case 3:
digitalWrite(pin2, HIGH);
case 4:
case 5:
digitalWrite(pin1, HIGH);
case 6:
case 7:
default:
if (dir){
_step++;
}else{
_step--;
if(_step>7){
_step=0;
if(_step<0){
_step=7;
delay(1);
Here's the sketch for the servo:
#include <Servo.h>
Servo servo; // create servo object to control a servo
int angle = 10;// twelve servo objects can be created on most boards
// variable to store the servo position
void setup () {
servo.attach(8); // attaches the servo on pin 9 to the servo object
servo.write(angle);
for (angle = 10; angle < 180; angle++)
servo.write(angle); // tell servo to go to position in variable 'pos'
delay(5); // waits 15ms for the servo to reach the position
for(angle = 180; angle > 10;angle--)
servo.write(angle);
delay(5);
I'm new at coding and this is my first time ever using Arduino. Any help is appreciated.
I haven't run servos with steppers but if you want to run multiple things at once you should look into Accelstepper library, I think it will be easier for you to code.
Their is a thread on google that shows using a stepper and servo at the same time that looks pretty straight forward to implement.
look here for code
@ElmiraShoara, to make it easy for people to help you please modify your post and use the code button </>
so your code looks like this
and is easy to copy to a text editor. See How to use the Forum
Your code is too long for me to study quickly without copying to a text editor.
Also please use the AutoFormat tool to indent your code for easier reading.
These links may help
Several Things at a Time
Stepper Motor Basics
Simple Stepper Code - especially the 2nd example
AccelStepper library
Planning and Implementing a Program
...R
int pin1 = 10;
int pin2 = 11;
int pin3 = 12;
int pin4 = 13;
  switch(_step){
    case 0:
    case 1:
     case 2:
     case 3:
       case 4:
       case 5:
       case 6:
     case 7:
 default:
if (dir){
  _step++;
}else{
  _step--;
if(_step>7){
  _step=0;
if(_step<0){
  _step=7;
delay(1);
#include <Servo.h>
void setup () {
 servo.write(angle);
    servo.write(angle);
    delay(5);
  }[pre][/pre]
