Hi!
I wanted to build a machine using an Arduino Uno and a CNC Shield v3. This machine should consist of 2 rotary axes and 1 translational axis (ít's used for winding) . I bought 3 stepper motors (NEMA 11, 17 and 23) and fitting drivers for them to use in combination with the CNC Shield. The plan was to generate a GCODE file and read and execute it with something like the UGS (Universal G-Code Sender).
But here is where my little knowledge leaves me hanging:
As I learned the CNC Shield doesn't support a rotary axis in GRBL and UGS.
So here are my questions:
Is there a way to use x and y axes as rotary axes using GCode in this setup so I can use commands in degrees instead of mm? Or is there a rule of thumb on how to translate the mm moved in GCode to a rotation?
For example when using a timing belt with 2 pulleys.
Motor: 1,8° ;200 Stepper with 1600Steps/rev
Small one: 14 teeth (active) d=22,28 mm
Big one: 34 teeth (passive) d=54,11 mm -
Is there another cheap way to make this work or is there some software or plugin I am missing? Or am I forced to write my own library for this project?
After searching the internet a bit for projects like this I am kind of disheartened since there are an infinite amount of 3D printer tutorials out there but they are only using translational movement. Whenever there is a rotational axis mentioned it's either that it is not supported by GRBL or that there is a board used that supports 5 axes.
But since I actually just need 3 I don't see why it would be necessary to buy a new board.
Thanks in advance.
