I am using an Arduino Mega ADK and a Sparkfun bluetooth Mathe Silver. It works fine for them to communicate via bluetooth. Also I have a small motor which runs on 3-5V, which works fine when using it with the Ardunio only.
Now I want to use both of them at once. I connected the 5V-PIN to the motor and the 3V-PIN to the bluetooth board. Whenever the motor starts the run the bluetoot board immediately disconnectes from the smartphone. When I run the motor and connect the bluetooth power PIN right in that moment, the motor stops running. So this schould be a power issue. The Arduino runs with a 12V-DC power supply and with the usb cable connected to the computer.
It is the H-Bridge as shown in the tutorial: L293NE
The motor really works finde with that setup. I can control it perfectly from the Arduino Board. I just cant use the motor and the bluetooth board at the same time.
I found the solution. It works when the bluetooth board is connected to the 5V PIN as well. Also there has been a logic error. The bluetooth board shpuldnt read messages to fast. I integrated a delay of 20 ms each time a byte is read. This prevents the device from disconnecting too.
