Running a DC motor continuously using a PWm command while doing other tasks
I am trying to keep a DC motor running at a slow speed using a PWM command through analogwrite within loop and then trying to check time as well as checking a sound sensor. However a single just the analogwrite command does not keep the motor running. Is there a better way?
Please show your code (using [code] tags) and you will get the help you seek.
Here is what I think the relevant portion of the code. i am attempting to use the analogwrite command right now. But want to have the motor running continuously.
//this next command should keep the motor running continuously at slow speed
analogWrite(motorControl, motorPWMlevel);
servo1.detach();
///time measurement is taken
tmElements_t tm;
if (RTC.read(tm)) {
Serial.print("Ok, Time = ");
// print2digits(tm.Hour);
//Serial.write(':');
//print2digits (tm.Minute);
//Serial.print(tm.Minute);
//RTC.read;
Serial.print(tm.Hour);
if(tm.Minute == whentodraw) {
hourdraw();
unsigned long startMillis= millis(); // Start of sample window
unsigned int peakToPeak = 0; // peak-to-peak level
unsigned int signalMax = 0;
unsigned int signalMin = 1024;
// collect data for 50 mS
while (millis() - startMillis < sampleWindow)
sample = analogRead(0);
if (sample < 1024) // toss out spurious readings
if (sample > signalMax)
signalMax = sample; // save just the max levels
else if (sample < signalMin)
signalMin = sample; // save just the min levels
peakToPeak = signalMax - signalMin; // max - min = peak-peak amplitude
double volts = (peakToPeak * 5.0) / 1024; // convert to volts
Serial.println(volts);
servo1.attach(servoPin1);
if (volts > soundlevel) {
drawsound();
Welcome to the Forum
Please post your entire code.
http://forum.arduino.cc/index.php/topic,148850.0.html
then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
PWM provides a continuous signal, the motor will run until you stop it.
When you use the Servo library it takes over the Timer that is used to provide PWM on pins 9 and 10 on an Uno. RTFM
Because you did not post the full program we cannot tell what pins you are using.
...R
      if (sample < 1024)
seems pretty pointless to me.
