Hey there everyone, I watched a youtuber a couple of days ago and I followed the hardware and software that was written. The difference is that I implemented 6 LED lights instead of 3 and everything is working correctly. The one issue I'm currently having is on my line that states light show which is an else if statement, I have my 6 lights follow a certain pattern but I want it to loop 10 times without having to copy the HIGH LOW in the "digitalWrite" for 10 additional sets of lines of code which seems extremely inefficient to me. Is there any way to incorporate a for loop inside of an else if loop so that I can just run the loop that way? Any help that can be provided will be greatly appreciated. I wanted to note that I code each light to a number in the programming pins on my Arduino uno, which I use a wire to hook up to a 220 ohm resistor which hooks to the power pin of my LED, I then have a cable going from the negative side of the LED which then returns to the ground strip which is hooked up to ground on the unit. I went ahead and left a comment above the else if statement explaining what I want to do inside of it. Below is my code.
String command;
#define yellow1LED 8
#define green1LED 9
#define red1LED 10
#define yellow2LED 11
#define green2LED 12
#define red2LED 13
pinMode(yellow1LED, OUTPUT);
pinMode(green1LED, OUTPUT);
pinMode(red1LED, OUTPUT);
pinMode(yellow2LED, OUTPUT);
pinMode(green2LED, OUTPUT);
pinMode(red2LED, OUTPUT);
delay(2000);
Serial.println("Type Command (yellow, green, red, light show, all, off)");
if (Serial.available()) {
command = Serial.readStringUntil('\n');
command.trim();
if (command.equals("yellow")) {
digitalWrite(yellow1LED, HIGH);
digitalWrite(green1LED, LOW);
digitalWrite(red1LED, LOW);
digitalWrite(yellow2LED, HIGH);
digitalWrite(green2LED, LOW);
digitalWrite(red2LED, LOW);
else if (command.equals("green")) {
digitalWrite(yellow1LED, LOW);
digitalWrite(green1LED, HIGH);
digitalWrite(yellow2LED, LOW);
digitalWrite(green2LED, HIGH);
else if (command.equals("red")) {
digitalWrite(red1LED, HIGH);
digitalWrite(red2LED, HIGH);
//I want this "light show" to loop 10 times inside of this else if statement
else if (command.equals("light show")) {
else if (command.equals("all")) {
else if (command.equals("off")) {
else {
Serial.println("bad command");
Serial.print("Command: ");
Serial.println(command);
