I have a question for you guys. Having fun learning Arduino, but I haven't found anything to help me get going on this latest endeavor.
I am building a system that will dose a chemical for water treatment to a certain level based on 3 user inputted variables. The user input variables will be done via potentiometers and a simple LCD Readout. I'll then have a formula that will tell me how much fluid must be dosed by the motor driven pump.
The pump is most likely going to be a stepper, such that I can control exactly how much it is rotating for precise dosing. Spec sheet attached. (Note there is also a DC motor version, I'd prefer step). I could build an h-bridge driver, or use the attached off the shelf drive which takes a 0-5v input to run the motor. Low mode on the controller ranges from 0-150RPM.
The trick is that I will have a wide range of flowrates that will require me to run the motor from .65RPM to 28RPM continuously. Given how low these speeds are, the alternative to continuous operation is I run the motor at a duty cycle at a faster intantaneous flow rate to achieve my nominal average rate over time.
The problem with duty cycle is I only know how to do that with delay in the loop, which I assume will make user adjustment of the control variable vary glitchy as they will only update in the loop with the long motor cycle delay. Is there a better way to do that?
Alternatively, I could use microstepping, but I currently do not know how to do that.
Now.. to make this discussion even larger, I am actually trying to do something VERY similar, only with a simpler system that uses a brushed DC motor with encoder speed feedback and PWM. I cannot PWM it low enough, so trying to figure out how to output a PWM intermittently.
Boxer 9K 9QQ.pdf (342 KB)
UI Stepper Driver Assy.pdf (512 KB)
