running a robot
hey,
maybe I have some mistake in my thoughts. I want to move my robot but he doesn`t move.
Arexx chassis RP5/RP6 (https://www.conrad.de/de/arexx-fahrgestell-robby-rp5rp6-roboter-191152.html)
FabScan Shield (http://www.watterott.com/de/Arduino-FabScan-Shield)
A4988-driver (http://www.watterott.com/de/Pololu-A4988-Schrittmotortreiber)
  • i limited it to 800mV
Arduino Uno
Stepper Motor: Bipolar, 200 Steps/Rev, 20×30mm, 3.9V, 0.6 A/Phase (Pololu - Stepper Motor: Bipolar, 200 Steps/Rev, 20×30mm, 3.9V, 0.6 A/Phase)
int enPin = 5;
int stepPin = 6;
int dirPin = 7;
  pinMode(enPin,OUTPUT);
  pinMode(stepPin,OUTPUT);
  pinMode(dirPin,OUTPUT);
  digitalWrite(enPin,LOW); // en muss auf Low= 0-> eingschalten
  digitalWrite(dirPin,HIGH); //Richtung festlegen
  for( int i = 0; i < 200;i++){
    digitalWrite(stepPin,HIGH);
    delay(1);
    digitalWrite(stepPin,LOW);
    delay(1);
Do you have your stepper driver plugged into position 2 (a.k.a "B")?
http://hci.rwth-aachen.de/fabscan_shield
Are these pulses driving full steps?
500 steps per second should drive the motor at 150 rpm. This seems pretty fast from starting from a stand still. Steppers can’t start at their top speed. They need to be accelerated up to speed.
Have you tried larger delays between pulses?
Yes, I have.
I assume that you are to provide power to the stepper drivers somewhere on this board. Do you have power source for the stepper hooked up?
johnwasser: I assume that you are to provide power to the stepper drivers somewhere on this board. Do you have power source for the stepper hooked up?
I have a 9V power source connected on the Fabscan Shield.
DuaneDegn: Are these pulses driving full steps?
500 steps per second should drive the motor at 150 rpm. This seems pretty fast from starting from a stand still. Steppers can't start at their top speed. They need to be accelerated up to speed.
One turn is 200 steps. I tried larger delays and the function delayMicroseconds(), it doesn't help.
Are you getting any vibration or noise from the motor?
Thanks :D I find my problem, the gears doesn't fit that well:(.
