Running a stepper back and forth
Hi Peter, I’m interested in your complete pulse/direction controller job: equal pulse counts in both directions, adjustable ramps and endpoint pauses, board selection, and setup instructions. Mechanical drift would still need validation on your rig. I saw that you can handle signal-level matching and manual starting position, and want high pulse rates. Are you still looking for paid help? If so, which Leadshine model are you using, and what top pulse rate is essential for the test? I’m based in China, work asynchronously with AI assistance, and haven’t delivered a commercial motion-control project.
Hi Peter. I develop embedded control systems and can help implement configurable travel, speed, acceleration and endpoint dwell for your endurance rig. If you are still looking for assistance, could you confirm the required pulse rate and driver interface so I can propose a scope and quote? www.product-prototype.com
Hi @peter-add, are you still looking for paid remote help with the stepper motor on your endurance test rig? I’m a mechatronics student in Mexico. I could write the Arduino sketch so you can adjust travel, speed, acceleration, and the pause at each end, then help you test it on your rig. If the project is still open, could you share the driver model, target pulse rate, and budget so I can put together a quote?
Hi Peter, is this still open? This is very doable on an Arduino Nano with the AccelStepper library: fixed step count each way (so no drift), configurable accel/decel ramps, max speed and dwell time, all set from a few values at the top of the sketch, or over serial so you never need to reprogram. I'd send you a wiring diagram for your step/dir driver plus tested code.
Happy to quote if you tell me your top speed and pulse count range.
My work and client reviews: https://gleeful-starlight-a67a5c.netlify.app
Orders with protected payment: LAMI - Embedded Firmware PCB Engineer STM32 ESP32 Motor Control | Profile | Fiverr
