Running a stepper motor and load cell
I have a problem similar to the one described here Help with stepper motor and load cell - Motors, Mechanics, Power and CNC - Arduino Forum.
I'm trying to run a stepper motor with a Stepper Motor Shield and a load cell with HX711.
The code is below (HX711_STEPPER). If I run this, I can get the load cell values on serial monitor without an issue. But the motor doesn't move; it makes a jittery noise.
If I run the motor code and load cell code separately, it works well! The separate codes (STEPPER and HX711_SERIAL) are below as well. I have attached the library files for HX711.
Not sure if I'm doing something wrong. Any help would be great!
HX711_STEPPER
#include "HX711.h"
// HX711.DOUT - pin #A1
// HX711.PD_SCK - pin #A0
HX711 scale(A1, A0); // parameter "gain" is ommited; the default value 128 is used by the library
const int stepPin = 6;
const int dirPin = 7;
const int enPin = 8;
 Serial.begin(38400);
 pinMode(6, OUTPUT);
 pinMode(7, OUTPUT);
 pinMode(8, OUTPUT);
 digitalWrite(enPin, HIGH);      // stop
 Serial.println("h-climb  l-descend  s-stop");
 Serial.println("HX711 Demo");
 Serial.println("Before setting up the scale:");
 Serial.print("read: \t\t");
 Serial.println(scale.read()); // print a raw reading from the ADC
 Serial.print("read average: \t\t");
 Serial.println(scale.read_average(20));   // print the average of 20 readings from the ADC
 Serial.print("get value: \t\t");
 Serial.println(scale.get_value(5)); // print the average of 5 readings from the ADC minus the tare weight (not set yet)
 Serial.print("get units: \t\t");
 Serial.println(scale.get_units(5), 1); // print the average of 5 readings from the ADC minus tare weight (not set) divided
// by the SCALE parameter (not set yet)
 scale.set_scale(2280.f);                      // this value is obtained by calibrating the scale with known weights; see the README for details
 scale.tare();        // reset the scale to 0
 Serial.println("After setting up the scale:");
 Serial.println(scale.get_value(5)); // print the average of 5 readings from the ADC minus the tare weight, set with tare()
 Serial.println(scale.get_units(5), 1);        // print the average of 5 readings from the ADC minus tare weight, divided
// by the SCALE parameter set with set_scale
 Serial.println("Readings:");
 for (int x = 0; x < 2000; x++)
     Serial.println(scale.get_units(),1);
 if(Serial.available())
   char c = Serial.read();
   if(c=='l')
       //Serial.println("Descending..");
       digitalWrite(enPin, LOW);
       digitalWrite(dirPin, LOW);      // descend
   if(c=='h')
       //Serial.println("Climbing..");
       digitalWrite(dirPin, HIGH);      // climb
   if(c=='s')
     //Serial.println("Stopping..");
   digitalWrite(stepPin, LOW);
   delayMicroseconds(2);
   digitalWrite(stepPin, HIGH);
   //Serial.print("one reading:\t");
 //Serial.print("\t| average:\t");
 //Serial.print("\t");
 //Serial.println(scale.get_units(10), 1);
 //scale.power_down();    // put the ADC in sleep mode
   delay(1);
 //scale.power_up();
STEPPER
 pinMode(6, OUTPUT);
 pinMode(7, OUTPUT);
 pinMode(8, OUTPUT);
 //////// 1 time movement  /////////
//  digitalWrite(dirPin, HIGH);     // descend
//  for (int x = 0; x < 6000; x++)
//    digitalWrite(stepPin, HIGH);
//    delayMicroseconds(2000);
//    digitalWrite(stepPin, LOW);
   if(c=='l')
   if(c=='h')
   if(c=='s')
///////////// actual move //////////////
   delay(10);
 //delay(2000);    // delay pause in milliseconds
HX711_SERIAL
#include "HX711.h"
 Serial.print(scale.get_units(), 1);
 delay(100);
 scale.power_up();
HX711-master.zip (13.8 KB)
Please post a wiring diagram (not Fritzing) and describe how everything is powered. Post links to the product pages or datasheets of the components.
This code
is trying to make the motor move at 250,000 steps per second. That's ridiculous. Try changing it to
for about 2 steps per second. If that works then gradually increase the speed by reducing the delay()
However delay() is OK in a test program but it is not a good idea to use it is a real program. Have a look at how millis() and micros() are used for non-blocking timing in the second example in this Simple Stepper Code and more generally in Several Things at a Time
...R
Stepper Motor Basics
