What I really want to know is what is the box made of and how did you cut and assemble it. In building Ards over the years I've found one of the hardest things to do is build a nice looking sturdy and easy to construct case.
I know this topic is a bit old but in searching for the exact same type of info as the OPs orig post - which never did actually get answered here did it ?
Here are some answers :
Stepper Motor Life
Based on this doc it seems most non-super cheap steppers last quite a long time - MTBF of 1 million hours ?
Lifetime depends on exactly what you would expect it to from a basic engineering standpoint - temp, bearing quality, insulation life, radial load water and dust intrusion etc.
There are some great charts in there on most of these.
For my application I need rotation 24/7/365 for a load of about 1 pound axially in an outdoor environment so I was worried about stepper service life. Looks like its not much of an issue for something rotating so slowly with a low mass.
Some other findings - grease selection for the bearings is a factor :
Stepper Motor Service Life
And this
Lifetime for a Stepper Motor
The typical lifetime for a stepper motor is 10,000 operating hours. This approximates to 4.8 years; given the stepper motor operates one eight-hour shift per day. The lifetime of a stepper motor may vary in regards to user application and how rigorous the stepper motor is run.
Required Maintenance for a Stepper Motor?
Since stepper motors are brushless, they require no maintenance for wear and tear on brushes and commutators.
Also they sell IP65 sealed motors for harsh environments (and other IP ratings too I'm sure).
For general use I would guess running continuously at fairly low rpm your looking at 5 to 10 year lifetime for a 'normal' off the shelf motor. And like many things probably cheaper and better from a statistical standpoint to plan ahead for motor failure - stocking a spare is usually a better approach then trying to buy/build the very highest quality motor.
You're welcome
