According to the Adafruit documentation for the Music Maker Mp3 shield, processes can be run while the sound file/files are playing if run within the while loop playingMusic.
while (mp.playingMusic) {
// file is now playing in the 'background' so now's a good time
// to do something else like handling LEDs or buttons :)
stepper.moveTo(-400); // move this many pulses away from home position
stepper.runToPosition(); // Update the motor and wait for it to reach destination
delay(300);
stepper.moveTo(-100); // move this many pulses away from home position
delay(300);
The stepper code above works perfectly fine in a standalone sketch. As does the music code, it plays the music until stopPlaying is sent, in its standalone sketch.
Yes, I know a state machine is the best way to handle this, and I’m moving toward that but I don’t understand, why, if the docs says you can run things while the music is playing, I can’t seem to do so.
The motor moves one step and then the program stops
UPDATE:
for those having the same issue, the following code will play the music file and run the motor from the while playingMusic section of the code
I’ve excluded the defines constants instance and variables for brevity.
the accelstepper is set up on pins 4&5 so as not to conflict with the music shield pins
stepper.setMaxSpeed(1000); // Set max speed. Steps per second
stepper.setAcceleration(300); // set motor acceleration
stepper.setSpeed(1000);
Serial.println("Adafruit VS1053 Library Test");
// initialise the music player
if (!musicPlayer.begin()) { // initialise the music player
Serial.println(F("Couldn't find VS1053, do you have the right pins defined?"));
while (1);
Serial.println(F("VS1053 found"));
musicPlayer.sineTest(0x44, 500); // Make a tone to indicate VS1053 is working
if (!SD.begin(CARDCS)) {
Serial.println(F("SD failed, or not present"));
while (1); // don't do anything more
Serial.println("SD OK!");
// Set volume for left, right channels. lower numbers == louder volume!
musicPlayer.setVolume(20, 20);
// This option uses a pin interrupt. No timers required! But DREQ
// must be on an interrupt pin. For Uno/Duemilanove/Diecimilla
// that's Digital #2 or #3
// See http://arduino.cc/en/Reference/attachInterrupt for other pins
// *** This method is preferred
if (!musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT))
Serial.println(F("DREQ pin is not an interrupt pin"));
// Start playing a file from the passed in music player object
if (!musicPlayer.startPlayingFile("trainxng.mp3")) {
Serial.println("Could not open file trainxng.mp3 from original musicPlayer");
while (1);
while (musicPlayer.playingMusic) {
Serial.println("In a second, stepper should move");
//this works in standalone version
stepper.moveTo(358); // move this many pulses away from home position
stepper.setSpeed(200); // Update the motor and wait for it to reach destination
stepper.run();
Serial.println("Done playing music");
