I'm sorry if the topic may seem a little unclear, but a little background should make it more clear. I'm currently building a desktop power supply from an old ATX PSU, where I'm planning to use all power outputs (3.3, 5, +-12 and ground), and also implement current/voltage monitoring on outputs using an Arduino Nano reading current levels from three separate ACS712 sensors on the positive outputs and display the readings on a Nokia 5110 LCD display.
To make things easy I thought of just running the arduino from the 5V output connected directly to the 5V pin on the arduino, however when I think of it, wouldn't that make problems with the ballast (a 10R, 10W resistor) also connected to the 5V output if I attempt to connect the arduino to the USB without removing either the resistor or taking the Arduino out first?
The easiest solution is perhaps to take two power resistors in series and connect them to the 12V output?
