My knowledge of arduino is extremely limited however it is for an assignment and I'm stuck.
Using the arduino Uno i was hoping to power sesnors that nedd a voltage of 6V according to their specs. How can I achieve this?
6volt is potentially dangerous for the Arduino.
Post the sensor datasheet link.
Inductive Proximity Switch
Model LJ12A3-4-Z/BX
Output Type NPN
Detecting Distance 4mm
Supply Voltage DC6-36V
Current Output 300 mA
Response Frequency 100Hz
Detect Object Iron
This is one of the sensors in question.
Mas_Rerap:
Inductive Proximity SwitchModel LJ12A3-4-Z/BX
Output Type NPN
This means is open-collector current-sinking output
supply voltage is not the same as signalling voltage
it can pull down upto 300mA
Detect Object Iron
Basically you can interface this to anything so long as you add a pull-up
resistor on the output to your logic's supply voltage (or use internal pull up).
You need at least 6V ro power it (perhaps share with Vin).
If it has long cable then use 2k2 pullup to 5V, the internal pullups are rather
weak for suppressing cable-borne interference. You can add 10nF to ground
on the output too in noisy electrical environments to cut down high frequency
interference.
