Running Average Coded
My project is to find the average temperature of industrial ovens through a J-Type thermocouple and the Adafruit Universal Thermocouple Amplifier MAX31856 Breakout... I went to Arduino Playground - RunningAverage to learn how and it all made sense, so I made the .h and .ccp folder and the code can read it but it keeps giving me this error code...
Arduino: 1.8.3 (Windows 7), Board: "Arduino/Genuino Uno"
In file included from C:\Users\McCarthyJ\Documents\Arduino\Final_Code\Final_Code.ino:2:0:
C:\Users\McCarthyJ\Documents\Arduino\libraries\RunningAverage/RunningAverage.h:2:2: error: expected unqualified-id before ':' token
(:source lang=c:)
C:\Users\McCarthyJ\Documents\Arduino\libraries\RunningAverage/RunningAverage.h:2:2: error: expected ')' before ':' token
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
I doubt the code arduino made is wrong so what should I do to fix this?
Thanks for any help!
Post the code, using code tags ("</>" button).
#include <Adafruit_MAX31856.h>
#include <RunningAverage.h>
// Use software SPI: CS, DI, DO, CLK
Adafruit_MAX31856 max = Adafruit_MAX31856(10, 11, 12, 13);
// use hardware SPI, just pass in the CS pin
//Adafruit_MAX31856 max = Adafruit_MAX31856(10);
RunningAverage myRA(10);
int samples = 10;
long count = 0;
  Serial.println("MAX31856 thermocouple test");
  pinMode(5, OUTPUT);
  myRA.clear(); // explicitly start clean
  max.begin();
  max.setThermocoupleType(MAX31856_TCTYPE_J);
  Serial.print("Thermocouple type: ");
  switch ( max.getThermocoupleType() ) {
    case MAX31856_TCTYPE_B: Serial.println("B Type"); break;
    case MAX31856_TCTYPE_E: Serial.println("E Type"); break;
    case MAX31856_TCTYPE_J: Serial.println("J Type"); break;
    case MAX31856_TCTYPE_K: Serial.println("K Type"); break;
    case MAX31856_TCTYPE_N: Serial.println("N Type"); break;
    case MAX31856_TCTYPE_R: Serial.println("R Type"); break;
    case MAX31856_TCTYPE_S: Serial.println("S Type"); break;
    case MAX31856_TCTYPE_T: Serial.println("T Type"); break;
    case MAX31856_VMODE_G8: Serial.println("Voltage x8 Gain mode"); break;
    case MAX31856_VMODE_G32: Serial.println("Voltage x8 Gain mode"); break;
    default: Serial.println("Unknown"); break;
  Serial.print("Cold Junction Temp: "); Serial.println(max.readCJTemperature());
  Serial.print("Thermocouple Temp: "); Serial.println(max.readThermocoupleTemperature());
  // Check and print any faults
  uint8_t fault = max.readFault();
  if (fault) {
    if (fault & MAX31856_FAULT_CJRANGE) Serial.println("Cold Junction Range Fault");
    if (fault & MAX31856_FAULT_TCRANGE) Serial.println("Thermocouple Range Fault");
    if (fault & MAX31856_FAULT_CJHIGH)  Serial.println("Cold Junction High Fault");
    if (fault & MAX31856_FAULT_CJLOW)   Serial.println("Cold Junction Low Fault");
    if (fault & MAX31856_FAULT_TCHIGH)  Serial.println("Thermocouple High Fault");
    if (fault & MAX31856_FAULT_TCLOW)   Serial.println("Thermocouple Low Fault");
    if (fault & MAX31856_FAULT_OVUV)    Serial.println("Over/Under Voltage Fault");
    if (fault & MAX31856_FAULT_OPEN)    Serial.println("Thermocouple Open Fault");
  myRA.addValue(rn * 0.001);
  samples++;
  Serial.print("Running Average: ");
  Serial.println(myRA.getAverage(), 3);
  if (samples == 60)
    samples = 0;
    myRA.clear();
  delay(100);
    if (max.readThermocoupleTemperature() > 30)
      digitalWrite(5, HIGH);   // turn the LED on (HIGH is the voltage level)
      delay(1500);                       // wait for a second
      digitalWrite(5, LOW);    // turn the LED off by making the voltage LOW
      delay(500);                       // wait for a second
This code is a combination of the thermocouple Amplifier, the running average and the code at the bottom just sets a light off at a certain temp that I can change
Someone needs to learn C.
"int samples = 10,11,12,13;"
This is technically correct, but belongs in an obfuscation contest.
What do you want samples to be? It can only be one number.
I know this is my first time coding so I'm slowing learning... I put that there because I wasn't sure which one I wanted to do and I just forgot to change it, it's supposed to be 10
Unfortunately, you will find many things wrong within the Arduino Playground. I think the offending line is a uncommented comment. Just add the comment lines.
//(:source lang=c:)
RunningAverage.h
 (:source lang=c:)
#ifndef RunningAverage_h
#define RunningAverage_h
//    FILE: RunningAverage.h
//  AUTHOR: Rob dot Tillaart at gmail dot com
// PURPOSE: RunningAverage library for Arduino
//     URL: http://arduino.cc/playground/Main/RunningAverage
// HISTORY: See RunningAverage.cpp
// Released to the public domain
// backwards compatibility
// clr() clear()
// add(x) addValue(x)
// avg() getAverage()
#define RUNNINGAVERAGE_LIB_VERSION "0.2.04"
#include "Arduino.h"
class RunningAverage
public:
    RunningAverage(void);
    RunningAverage(int);
    ~RunningAverage();
    void clear();
    void addValue(float);
    void fillValue(float, int);
    float getAverage();
    float getElement(uint8_t idx);
    uint8_t getSize() { return _size; }
    uint8_t getCount() { return _cnt; }
protected:
    uint8_t _size;
    uint8_t _cnt;
    uint8_t _idx;
    float   _sum;
    float * _ar;
#endif
// END OF FILE
Okay I tried that and it didn't work it still gives me the same error code..
Post YOUR code.
I did it was the second thing I posted...
But you've corrected it since then, right?
Not really, I just changed it a bit and i edited the one I posted so it's correct
Obviously, it is not correct.
Post the code again, in a new post, together with the error message.
This is my code…
int samples = 10;
long count = 0;
  pinMode(5, OUTPUT);
  max.begin();
    if (fault) {
      samples++;
      if (samples == 60)
        samples = 0;
        myRA.clear();
      delay(100);
This is the error code I keep getting…
 (:source lang=c:)
exit status 1
Invalid library found in C:\Users\McCarthyJ\Documents\Arduino\libraries\Adafruit_Circuit_Playground: C:\Users\McCarthyJ\Documents\Arduino\libraries\Adafruit_Circuit_Playground
Invalid library found in C:\Users\McCarthyJ\Documents\Arduino\libraries\analog_sensors: C:\Users\McCarthyJ\Documents\Arduino\libraries\analog_sensors
The error message says the error is in a header file you didn't post.
//(:source lang=c:)
Proof please.
The error is in the code you didn't post, as clearly stated in the error message. Fix that by commenting out the offending line, as suggested earlier.
(:source lang=c:)
//(:source lang=c:)
// clr() clear()
public:
    ~RunningAverage();
    void clear();
    float getAverage();
protected:
    uint8_t _size;
    uint8_t _cnt;
    uint8_t _idx;
    float   _sum;
    float * _ar;
#endif
// END OF FILE
That code your posted is probably not in "C:\Users\McCarthyJ\Documents\Arduino\libraries" which is where the code containing the error resides.
it is in there I double checked
The compiler does not lie.
