I've got two 12v car batteries connected in parallel and was using one quick disconnect switch, but realized I need two because even with the negative cable disconnected I was still getting power. Does anyone know why? The only way to cut the power is use two quick disconnects and disconnect the two negative terminals.
What is your application? What is connected more to the Arduino board?
If the path to the source is not closed (like you say that you have the negative cable disconnected) it's impossible to have power. How are you measuring that power? You see the board running?
Yes, a schematic, and maybe a picture of the batteries and the conductors connected to them, too. And tell us exactly why you think that you "still getting power." If you're measuring something, tells us exactly where you're measuring, and exactly what the readings are.
Our impression is that you believe that power flows to the load with the negative terminal of the paralleled batteries disconnected from the load. That may not be what you intend to report. It may be that you're measuring the current at one of the batteries' negative terminals. If that's so, then you're measuring current flowing between the batteries. Not unexpectable; it's almost certain that their voltages aren't precisely equal, and, with the very low impedances involved, a little bit of voltage difference will give rise to a noticeable current.
Connecting batteries in parallel is almost always a bad idea. They cross charge.
You are best to connect them together through a diode on each battery.
If you have sensors or other things connected to the ground then that will supply a return path for the batteries and you will still get power. To test this disconnect all the circuitry from the arduino and just have the power.
