int main(){
}; int x
int a;
int b;
int c;
x=0;
a=0;
b=0;
c=1;
a=b+c;
b=c;
c=a;
x=x+1;
when x>5;
return 0;
exit status 1
expected initializer before 'int'
this error occurs before int a
Can anyone help
Your error is because there's no semicolon after "int x", but that's the least of your problems.
The posted code just needs a little syntax cleanup:
int x;
int a;
int b;
int c;
x=0;
a=0;
b=0;
c=1;
// maybe Serial.begin(9600);
a=b+c;
b=c;
c=a;
x=x+1;
// maybe Serial.println (a); // want to see some output?
if (x<6){
// make another pass thru loop
else {
while(1); // do nothing until reset is pressed
Thanks! what does serial mean? and also what is serial.begin(9600)? Thanks
Serial.begin() and Serial.print() or Serial.println() are how you display stuff on the Serial monitor in the IDE.
Thanks! however, the line a=b+c says that a does not specify a type.
int x;
int y;
int b;
int c;
x=0;
y=0;
b=0;
c=1;
}y=b+c;
b=c;
c=y;
x=x+1;
when (x<6);{
return 0;
Serial.println(y)
else{
while(1);
the problem is that y=b+c is returning error y does not name a type
system
March 21, 2017, 4:22pm
10
The } just in front of the y ends loop() and so everything from there onwards is not in any function.
int x;
int y;
int b;
int c;
x=0;
y=0;
b=0;
c=1;
y=b+c;
b=c;
c=y;
x=x+1;
if (x<6);{
return 0;
Serial.println(y)
else{
while(1);
it is now returning that else has no if. why would this occur?
if (x<6);{
You should look up the syntax of if (and C++ in general).
Starting late on the homework?
Some general tips:
use sensible variable names
use Serial.begin() if you want to use Serial
put code to run once into setup
only make variables global if they have to be shared
don't try to return values from void functions
