Running Graph display on TFT LCD
I would like to display the value of 2 sensors on a TFT LCD display in running graph format. the 2 graphs will have different colors.
Basically all i need is a live trend rather than exact pixel values but that would be nice too.
Are there any projects out there with some examples to get me started in selecting the right lcd and a start with the code on a Uno?
I have only found some barograph examples on dot matrix lcd’s
Any help is appreciated…
OK. You have permission to do so.
I don't know how you are going to draw a graph without knowing exact pixel values. I doubt the library has a drawALineAbouthHere() method.
You can use one of these TFT Lcds, LINK. It uses the UTFT and UTouch libraries, and it also has another library Ubuttons.
The UTFT library has a demo that shows a moving graph, that you can use your make you graph. It will require you to do some writing, because there is no Make_Graph_With_These_Values function.
I too have the Lcd.
Thank you Hazardsminds.
Your answer is very useful and ives a good starting point.
Much appreciated.
