Running Gray code on Due - dedicated hardware pins?
I recall that somewhere in ATmel docs there is a passing mention about running Gray code. Just wondering ( cannot find it ) if it is ONLY on specific pins and limited to two bits Gray code. Cheers Vaclav
There is no single "gray code", and no hardware support should be required in most applications. A "gray code" is any code in which only a single bit changes between successive token values. There are gazillions of different gray code implementations for different applications. For instance, one particular gray code counter (out of MANY possible ones), could have a sequence like this:
0 = 0b000 1 = 0b001 2 = 0b011 3 = 0b111 4 = 0b010 5 = 0b110 6 = 0b100 7 = 0b101
Regards, Ray L.
Ray, that's not a gray code, the transition from 7 to 0 involves changing two bits. This works:
0 = 0b000
1 = 0b001
2 = 0b011
3 = 0b010
4 = 0b110
5 = 0b111
6 = 0b101
7 = 0b100
Pete
el_supremo:
Ray, that’s not a gray code, the transition from 7 to 0 involves changing two bits.
This works:
0 = 0b000
1 = 0b001
2 = 0b011
3 = 0b010
4 = 0b110
5 = 0b111
6 = 0b101
7 = 0b100
Pete
Yup, right you are!
Regards,
Ray L.
There is an algorithm to generate a gray code of any given number of bits. I had occasion to use it many years ago but I have long since forgotten it. No doubt wikipedia has an article about it, probably with a method of generating a gray code.
Pete
