Running more servo motors with Stickduino?
I have a Stickduino and I am experimenting with servo motors using the servo.h library in Examples from the Arduino IDE. Reading servo.h I see it says it only works on pins 9 and 10. Is there anyway to modify this library to work on other digital pins or another servo library for Arduino I can use that will utilize more pins so I can run more servo motors?
The latest Arduino release can use any digital pin to drive a servo. If you are using an earlier version than 0017 you can download the library code here: http://www.arduino.cc/playground/Code/MegaServo
