Running multiple Arduinos in series.
So I am trying to figure out how to start 10 arduinos at the same time to run different programs. I my project class there are 10 teams that are making 10 instruments so I am trying to figure out how to get all of them to start at the same time in the easiest way. I was thinking about wiring a large button from all of the inputs and have them share a ground. so that way when you press the button they should all start at the same time. That seem more complicated then it should be. Is there an easier way. I was also thinking about programming a master arduino that's only job is to start the other ones but I am unsure if that would work without having to change the code for every team. Any help would be appreciated.
Why don't you supply them all from the same power and turn them all on with a mains switch?
The power supply is more important than the switch. Once you have worked out a safe way to power them all then you can work on synchronization.
Having all read the same input signal and then starting is a good way.
Can also have 1 send out that signal vs a switch. Then you can have that one send the signal periodically to keep them in sync in case variations between resonators causes them to drift a little over time.
What you are describing is running them in parallel.
...R
