Running multiple motors for x amount of time with two buttons
Hello, newbie here!
I wan’t to run two motors, with three buttons. One button for motor 1, one button for motor 2 and the last one is emergency stop for both.
I can only get the first motor to run, and not the second. The emergency stop also works. I tried naming the motors driveStepper1 and driveStepper2, but that doesn’t work. I can upload the program to my Arduino. Does anyone know where in my code I am doing something wrong?
Thanks in advance!
//end
// motor 1
int Pin1 = 4; //IN1 is connected to 4
int Pin2 = 5; //IN2 is connected to 5
int Pin3 = 6; //IN3 is connected to 6
int Pin4 = 7; //IN4 is connected to 7
int switch1 = 2; //red button left
int switch2 = 3; //yellow button
//motor 2
int Pin5 = 8; //IN1 is connected to 8
int Pin6 = 9; //IN2 is connected to 9
int Pin7 = 10; //IN3 is connected to 10
int Pin8 = 11; //IN4 is connected to 11
int switch3 = 12; //red button right
int pole1[] ={0,0,0,0, 0,1,1,1, 0};//pole1, 8 step values
int pole2[] ={0,0,0,1, 1,1,0,0, 0};//pole2, 8 step values
int pole3[] ={0,1,1,1, 0,0,0,0, 0};//pole3, 8 step values
int pole4[] ={1,1,0,0, 0,0,0,1, 0};//pole4, 8 step values
int poleStep = 0;
int dirStatus = 3; // motor status 3 = stop (don't change)
int unsigned long time_now=0;
int period=2000; //(runtime in milliseconds)
//motor 1
pinMode(Pin1, OUTPUT); //Define output
pinMode(Pin2, OUTPUT);
pinMode(Pin3, OUTPUT);
pinMode(Pin4, OUTPUT);
pinMode(switch1,INPUT_PULLUP); // Define input
pinMode(switch2,INPUT_PULLUP); //
//motor 2
pinMode(Pin5, OUTPUT);
pinMode(Pin6, OUTPUT);
pinMode(Pin7, OUTPUT);
pinMode(Pin8, OUTPUT);
pinMode(switch3, INPUT_PULLUP);
if(digitalRead(switch1) == LOW) //If red button is pressed, motor status = 1 and motor drives clockwise
  dirStatus =1;
  time_now=millis(); // time starts at 0
}else if(digitalRead(switch2) == LOW) //íf yellow button is pushed, motor status = 3 and motor 1 and 2 stops
  dirStatus =3;
if((dirStatus == 1) && (millis()<time_now+period)){ //If motor status is = 1, the motor runs in x amount of milliseconds
 poleStep++; // Motor runs clockwise
  driveStepper1(poleStep);
//motor 2
if(digitalRead(switch3) == LOW)
{dirStatus = 1;
time_now=millis();
  dirStatus =3;
if((dirStatus == 3) && (millis()<time_now+period)) {
  poleStep++;
  driveStepper2(poleStep);
}else{
driveStepper1(8); //motor 1
if(poleStep>7){
 poleStep=0;
if(poleStep<0){
 poleStep=7;
}driveStepper2(8); //motor 2
if(poleStep>7){
 poleStep=0;
if(poleStep<0){
 poleStep=7;
delay(1); //Update every millisecond
}// loop
void driveStepper1(int c)
// motor 1
   digitalWrite(Pin1, pole1[c]);
   digitalWrite(Pin2, pole2[c]);
   digitalWrite(Pin3, pole3[c]);
   digitalWrite(Pin4, pole4[c]);
void driveStepper2(int c)
// motor 2
   digitalWrite(Pin5, pole1[c]);
   digitalWrite(Pin6, pole2[c]);
   digitalWrite(Pin7, pole3[c]);
   digitalWrite(Pin8, pole4[c]);
Look at the example BlinkWithoutDelay.
That is a program explaining how to do multiple things at once.
fedefrede69:
To make it easy for people to help you please modify your post and use the code button </>
so your code
looks like this
and is easy to copy to a text editor. See How to use the Forum
Also please use the AutoFormat tool to indent your code consistently for easier reading.
In the meantime have a look at how millis() is used to manage timing without blocking in Several Things at a Time. And see Using millis() for timing. A beginners guide if you need more explanation.
You may find it easier to create your program if you use the AccelStepper library as it handles all the housekeeping.
...R
ieee488:
Found this video about BlinkWithoutDelay, which helped a lot! - Understanding Blink Without Delay - YouTube
Now I stumbled onto a new problem :slight_smile:
When I press left button (switch1), motor 1 runs. When I press right button(switch3), motor 2 runs. Now if I press left button again, both motor 1 and motor 2 will run. It will reset if I press the emergency button (switch2), and I can press left button (switch1) and run motor 1 without running motor 2. Where does it go wrong?
// motor 1
int switch1 = 2; //red button left - motor 1 start
int switch2 = 3; //yellow button - emergengcy stop
//motor 2
int switch3 = 12; //red button right - motor 2 start
int poleStep1 = 0;
int poleStep2 = 0;
int dirStatus1 = 3; // motor status 3 = stop (don't change)
int dirStatus2 = 3;
  //motor 1
//motor 2
 void motor1()
  //MOTOR 1
    dirStatus1 =1;
    dirStatus1 =3;
  if((dirStatus1 == 1) && (millis()<time_now+period)){ //If motor status is = 1, the motor runs in x amount of milliseconds
   poleStep1++; // Motor runs clockwise
    driveStepper1(poleStep1);
 }else{
 if(poleStep1>7){
   poleStep1=0;
 if(poleStep1<0){
   poleStep1=7;
 void motor2()
  //MOTOR 2
  if(digitalRead(switch3) == LOW) //If red button is pressed, motor status = 1 and motor drives clockwise
    dirStatus2 =1;
    dirStatus2 =3;
  if((dirStatus2 == 1) && (millis()<time_now+period)){ //If motor status is = 1, the motor runs in x amount of milliseconds
   poleStep2--; // Motor runs clockwise - polerne er omvendt
    driveStepper2(poleStep2);
 }else{
  driveStepper2(8); //motor 1
 if(poleStep2>7){
   poleStep2=0;
 if(poleStep2<0){
   poleStep2=7;
 motor1();
 motor2();
  // motor 1
  // motor 2
//end
Rather than this
 motor1();
 motor2();
I suggest you do it like this
 checkSwitches();
 motor1();
 motor2();
so that you separate the business of getting the switch values from the business of operating the motors. Save the switch values to variables and then check those variables to decide which motor should do what.
It will also mean that you can print the switch values as part of your debugging.
...R
