Hi everyone,
I’m trying to build the following on my Yun:
- A webserver that takes commands through GET/PUT (used the Yun Bridge for that until now)
- Being able to run .hex files (other sketches) which are stored on SD card
- Through above mentioned webbased api-calls, start the various sketches on the SD card, depending on the commands/parameters i specify in the web-calls.
I’m regularly running into my 32k limit because i’m working with an LED matrix and have various animations that take up a lot of memory. So I was trying to find a way to run sketches / .hex files from the SD card i plugged in, that will allow me to just use the 32K for the active sketch and have enough memory left at runtime, etc.
The nicest looking option i found is http://bitlash.net and i got really excited, only to find out that the BitlashWebServer Example is 105% of my available memory. I am a bit lost here, i expected to have enough memory as the bitlash bootloader only uses 4k.
Is there anyone who got this to work on his/her Yun? Or could help me to meet my requirements on the Yun?
Thanks in advance for all the help.
Best regards,
Ralph
