Hello,
I am building a type of 3D printer that uses 8 hoists, each powered by a NEMA 17 motor. The main software is written in processing but im using two arduino Megas to control the motors and various other bits (fans heaters etc).
I have written some code that takes a string sent from P3 and interprets it into steps and direction for each motor which works fine. The issue is that the motors run in series not parallel, which means the print would be ugly and slow.
is there a way to run all 8 motors in parallel so that they start their first step at the same time and their last step at the same time (each motor would run at different speed)?
I think the AccelStepper/ Multistepper library could do it but don't know what the code should look like.
the string that's received looks something like this:
letter (A-H) = which motor, first number = direction (1 = clockwise, 0 = anticlockwise), next 4 numbers are the amount of steps.
Heres the current code:
int steps[] = {23, 25, 33, 37, 41, 45, 22, 26, 32, 36, 40, 44, 48}; //motor pin number array. these pins set whether power is on or off
int dir[] = {22, 24, 31, 35, 39, 43, 24, 28, 30, 34, 38, 42, 46}; //power pin number array. These are the pins that send power to each motor.
int limitpin[] = {22, 10, 4, 12, 23, 11, 5, 9};//first four are top, second four are bottom
int limits[] = {0, 0, 0, 0, 0, 0, 0, 0}; // first four are top, second four are bottom
char limChar[] = {'Z', '0', '0', '0', '0', '0', '0', '0', '0'};
char motor[] = {'A', 'B', 'C', 'D', 'E', 'F', 'G', 'H', 'I', 'J', 'K', 'L', 'M', 'N', 'Z'};
boolean stopped;
boolean done = true;
boolean received[13];
boolean completed[13];
char directions[13];
int nSteps[13];
int inc = 800;
int iSteps[] = {inc, inc, inc, inc, inc, inc, inc, inc, inc, inc, inc, inc, inc};
int mStepsXY = 0;
long sT[13];
int khz = 200;
boolean nw = false; //boolean to indicate whether the shownewdata function should run
const byte MaxChar = 64; //maximum number of characters a string sent over comms can have.
char input[MaxChar]; //input array for incoming information from the comms port
Serial.begin(56700); //opens the comms port - the port needs to be the same as in processing. The higher the number the faster it can communicate but increases error
for (int z = 0; z < 13; z++) {
pinMode(steps[z], OUTPUT); //Sets the power pins as outputs
digitalWrite(steps[z], LOW); //sets the motor pins to start as off if ((z > 0) { //this part is only ran for the first 8 loops as there are only 8 power pins
pinMode(dir[z], OUTPUT); //Sets the power pins as outputs
digitalWrite(dir[z], LOW); //sets the power pins to start as "off"
received[z] = false;
completed[z] = false;
if (z > 4) {
pinMode(limitpin[z], INPUT); //Sets the limit pins as inputs
readbytes();
void readbytes() {
//Defines the local variables
static boolean InProgress = false; //boolean to indicate whether a string is being put together or not
static byte ndx = 0; //placeholder for number of characters in the string
char start = '<'; //this is added to the start of the string before its sent to indicate when a new input has been sent
char finish = '>'; //this is added to the end of the string before its sent to indicate when a new input has finished being sent
char ReadChar; //this is the current value stored in the comms port
while (Serial.available() > 0 && nw == false) {
ReadChar = Serial.read(); //stores the current value in the comms port for analysis
if (InProgress == true) { //checks if we are currently putting a string together
if (ReadChar != finish) { //if the current value in the comms port is not the finish character (i.e ">") this evaluates to true
input[ndx] = ReadChar; //store the value in the input array
ndx++; //move to the next character in the string
if (ndx >= MaxChar) {
ndx = MaxChar - 1; //if the loop has ran more than the max length of string, overwrite the last entry
else {//if the current value in the comms port is the finish character (>) this evaluates to true
input[ndx] = '\0'; //adds a line break to the input array to finish the string
InProgress = false; //tells the program we're done putting a string together for now
ndx = 0; //set the input array index back to 0
nw = true; //gets ready to run the shownewdata function
interpretdata();
runhoists();
} else if (ReadChar == start) { //if the current value in the comms port is the start character (i.e "<") this evaluates to true
InProgress = true; //tells the program we are currently putting a string together
void interpretdata() {
if (input[0] == 'A') {
for (int i = 0; i < 8; i++) {
if (input[i * 6] == motor[i]) { //if the input char is the same as the motor indicator char...
directions[i] = input[(i * 6) + 1]; //the next input char is recorded as the direction
char strg[3];
for (int l = 0; l < 4; l++) {
strg[l] = input[(i * 6) + (l + 2)]; //the next 4 input chars are the number of steps
nSteps[i] = atoi(strg); //converts the no of steps string into an integer
received[i] = true; //record that that hoists info has been received for the next coordinate
for (int z = 0; z < 52; z++) {
input[z] = "";
Serial.flush();
for (int x = 0; x < 8; x++) {
if (nSteps[x] > mStepsXY) {
mStepsXY = nSteps[x];
void runhoists() {
if ((received[0] == true) && (received[1] == true) && (received[2] == true) && (received[3] == true)
&& (received[4] == true) && (received[5] == true) && (received[6] == true) && (received[7] == true)) {
if (directions[i] == '0') { // if direction info is 0
digitalWrite(dir[i], HIGH); // set motor direction to anticlockwise
else if (directions[i] == '1') {
digitalWrite(dir[i], LOW); // if its 1 set motor direction to clockwise
for (int k = 0; k < ((mStepsXY/inc)+1); k++) {
for (int z = 0; z < inc; z++) {
if ((nSteps[i] > 0 ) && (z < nSteps[i])) {
sT[i] = micros();
while (micros() - sT[i] < khz) {
digitalWrite(steps[i], HIGH);
digitalWrite(steps[i], LOW);
sendback();
void sendback() {
received[i] = false; // clear the received signals
nSteps[i] = 0;
iSteps[i] = 0;
mStepsXY = 0;
// t = 0;
Serial.println("W"); // send a signal back to processing that the coord is done.
Serial.flush();
nw = false;
