I'm working on a code that read user message then check what letter is it at now then it make copy of that letter to be displayed on LED matrix
my problem is when I use many if statements I run out of memory
the problem is in this->copy_letter(letter_xxx); when it's called many times it consumes memory so fast
is there a way around it ?
the full code
#include "Animate_LED_matrix.h"
#include "user_letters.h"
#include "user_custom_letters.h"
//#define DEBUG
Animate_LED_matrix::Animate_LED_matrix(char local_rows[9],char local_cols[9]){
//#ifdef DEBUG
// Serial.begin(9600);
//#endif
//copy cols&rows pins numbers from user array to our local copy
for(int i=0; local_rows[i]; ++i){
this->rows[i]=local_rows[i];
++this->num_of_rows;
for(int i=0; local_cols[i]; ++i){
this->cols[i]=local_cols[i];
++this->num_of_cols;
// Set rows and cols pins as output
for(int i=0; this->rows[i]; ++i){
pinMode(this->rows[i],OUTPUT);
this->turn_off_everything();
for(int i=0; this->cols[i]; ++i){
pinMode(this->cols[i],OUTPUT);
void Animate_LED_matrix::turn_off_everything(){
for(int i=0; rows[i]; ++i){
digitalWrite(rows[i],HIGH);
for(int i=0; cols[i]; ++i){
digitalWrite(cols[i],LOW);
void Animate_LED_matrix::turn_on_everything(){
digitalWrite(rows[i],LOW);
digitalWrite(cols[i],HIGH);
void Animate_LED_matrix::copy_letter(char letter_to_copy[8][8]){
for(int i=0; i<this->num_of_cols; ++i){
for(int x=0; x<this->num_of_rows; ++x){
if(this->get_next_letter==true){
this->next_letter_to_print[x][i]=letter_to_copy[x][i];
}else{
this->letter_to_print[x][i]=letter_to_copy[x][i];
void Animate_LED_matrix::get_letter(char letter_to_get){
if(letter_to_get=='a'){this->copy_letter(letter_a);}
if(letter_to_get=='b'){this->copy_letter(letter_b);}
if(letter_to_get=='c'){this->copy_letter(letter_c);}
if(letter_to_get=='d'){this->copy_letter(letter_d);}
if(letter_to_get=='e'){this->copy_letter(letter_e);}
if(letter_to_get=='f'){this->copy_letter(letter_f);}
if(letter_to_get=='g'){this->copy_letter(letter_g);}
if(letter_to_get=='h'){this->copy_letter(letter_h);}
if(letter_to_get=='i'){this->copy_letter(letter_i);}
if(letter_to_get=='j'){this->copy_letter(letter_j);}
if(letter_to_get=='k'){this->copy_letter(letter_k);}
if(letter_to_get=='l'){this->copy_letter(letter_l);}
if(letter_to_get=='m'){this->copy_letter(letter_m);}
if(letter_to_get=='n'){this->copy_letter(letter_n);}
if(letter_to_get=='o'){this->copy_letter(letter_o);}
if(letter_to_get=='p'){this->copy_letter(letter_p);}
if(letter_to_get=='q'){this->copy_letter(letter_q);}
if(letter_to_get=='r'){this->copy_letter(letter_r);}
if(letter_to_get=='s'){this->copy_letter(letter_s);}
if(letter_to_get=='t'){this->copy_letter(letter_t);}
if(letter_to_get=='u'){this->copy_letter(letter_u);}
if(letter_to_get=='v'){this->copy_letter(letter_v);}
if(letter_to_get=='w'){this->copy_letter(letter_w);}
if(letter_to_get=='x'){this->copy_letter(letter_x);}
void Animate_LED_matrix::parse_msg(int index){
char local_current_letter;
bool is_symbol=false;
//String symbol;
if(index < this->user_msg.length()){
char local_current_letter=this->user_msg.charAt(index);
//here it checks if it's start of custom character
if(local_current_letter== "&" ){
is_symbol=true;
++index;
if(!this->get_next_letter) ++this->current_letter;
}else{
if(this->get_next_letter){
this->get_letter(local_current_letter);
}else{
if(local_current_letter != this->user_last_letter){
this->user_last_letter=local_current_letter;
void Animate_LED_matrix::shift_original_symbol(){
char start_point=this->current_base;
char current_col_of_current_letter=this->current_base;
//copy the same column to all rows
for(char i=0; i<this->num_of_cols; ++i){
for(char x=0; x<this->num_of_rows; ++x){
if(current_col_of_current_letter >= 8){
this->shifted_symbol[x][i]=this->next_letter_to_print[x][start_point-8];
}else{
this->shifted_symbol[x][i]=this->letter_to_print[x][start_point];
} // end row loop
++start_point;
++current_col_of_current_letter;
} // end column loop
void Animate_LED_matrix::check_cols_active_in_all(){
bool is_active=false;
if(this->shifted_symbol[x][i]){
is_active=true;
}else{
is_active=false;
break;
if(is_active){
this->which_col_active_in_all[i]=1;
if(this->which_col_active_in_all[i]){
this->shifted_symbol[x][i]=0;
void Animate_LED_matrix::turn_on_cols_active_in_all(){
this->check_cols_active_in_all();
for(char i=0; rows[i]; ++i){
for(char i=0; cols[i]; ++i){
}else{
continue;
delay(this->global_delay);
void Animate_LED_matrix::check_cols_have_2_dots_turned_on_on_seris(){
char num_of_dots_active=0;
if(num_of_dots_active < 2){
++num_of_dots_active;
}else{
break;
if(num_of_dots_active>1){
this->which_col_have_2_dots_turned_on_on_seris[i]=1;
void Animate_LED_matrix::turn_on_cols_have_2_dots_turned_on_on_seris(){
this->check_cols_have_2_dots_turned_on_on_seris();
for(char i=0; i<8; ++i){
if(which_col_have_2_dots_turned_on_on_seris[i]){
for(char x=0; rows[x]; ++x){
digitalWrite(rows[x],LOW);
for(char i=0; i<num_of_cols; ++i){
if(this->which_col_have_2_dots_turned_on_on_seris[i]){
for(char x=0; x<num_of_rows; ++x){
void Animate_LED_matrix::turn_on_cols_have_sperated_dots_turned_on(){
void Animate_LED_matrix::start_animation(){
this->shift_original_symbol();
this->turn_on_cols_active_in_all();
this->turn_on_cols_have_2_dots_turned_on_on_seris();
this->turn_on_cols_have_sperated_dots_turned_on();
void Animate_LED_matrix::reset_everything(){
this->which_col_active_in_all[i]=0;
this->which_col_have_2_dots_turned_on_on_seris[i]=0;
if(this->current_base==8){
this->current_base=0;
if(this->current_letter+1 < this->user_msg.length()){
this->current_letter+=1;
}else if(this->current_letter+1 >= this->user_msg.length()){
this->current_letter=0;
if(this->current_letter+2 <= this->user_msg.length()){
this->is_there_next_letter=true;
}else if(this->current_letter+2 > this->user_msg.length()){
this->is_there_next_letter=false;
void Animate_LED_matrix::loop_animation() {
if(this->current_letter == this->user_msg.length()-1){
this->get_next_letter=true;
this->parse_msg(0);
this->get_next_letter=false;
}else if(this->current_letter < this->user_msg.length()-1){
this->parse_msg(this->current_letter);
this->parse_msg((this->is_there_next_letter? this->current_letter+1 : 0));
//repeat each animation n of times
int counter=0;
start:
this->start_animation();
delay(1);
if(counter<10){
++counter;
goto start;
#ifdef DEBUG
Serial.println("finished animation");
#endif
++this->current_base;
this->reset_everything();
