My program is currently running out of SRAM, what I have is a program that runs a scrolling LED sign. What I'm wondering is if I can use a PROGMEM function to store some of the items into flash memory. Reading through the PROGMEM page on the arduino website I'm guessing no but I could be wrong. The problem I see is that a lot of the data is stored in a custom variable type. My code is below:
int Row1 = 2;
int Row2 = 3;
int Row3 = 4;
int Row4 = 5;
int Row5 = 6;
int Col6 = 7;
int Col5 = 8;
int Col4 = 9;
int Col3 = 10;
int Col2 = 11;
int Col1 = 12;
int Tx = 0;
int Ty = 0;
int y = 0;
int z = 0;
int WordSize = 0;
unsigned long t = 0;
//this is what defines a Letter on the most primitive letter
struct BaseLetter {
virtual char get( byte line, byte bit ) = 0;
virtual byte width( void ) = 0;
static const byte NUMBER_OF_LINES = 5;
//Define letters of variable width using this template struct
template<byte size>
struct Letter : public BaseLetter {
Letter( byte l0, byte l1, byte l2, byte l3, byte l4) :
line0(l0),line1(l1),line2(l2),line3(l3),line4(l4) {
unsigned line0 : size;
unsigned line1 : size;
unsigned line2 : size;
unsigned line3 : size;
unsigned line4 : size;
unsigned : 0;
virtual char get( byte line, byte bit ) {
switch (line){
case 0: return (line0&(1<<bit%size)?1:0); break;
case 1: return (line1&(1<<bit%size)?1:0); break;
case 2: return (line2&(1<<bit%size)?1:0); break;
case 3: return (line3&(1<<bit%size)?1:0); break;
case 4: return (line4&(1<<bit%size)?1:0); break;
return -1;
virtual byte width() { return size; }
DEFINE THE LETTERS
Letter<3> A = Letter<3>(
B010,
B101,
B111,
B101,
B101
Letter<3> B = Letter<3>(
B110,
B101,
B110,
B101,
B110
Letter<3> C = Letter<3>(
B011,
B100,
B100,
B100,
B011
Letter<3> D = Letter<3>(
B110,
B101,
B101,
B101,
B110
Letter<3> E = Letter<3>(
B111,
B100,
B111,
B100,
B111
Letter<3> F = Letter<3>(
B111,
B100,
B110,
B100,
B100
Letter<5> G = Letter<5>(
B01110,
B10000,
B10011,
B10001,
B01110
Letter<3> H = Letter<3>(
B101,
B101,
B111,
B101,
B101
Letter<3> I = Letter<3>(
B111,
B010,
B010,
B010,
B111
Letter<3> J = Letter<3>(
B011,
B001,
B001,
B101,
B010
Letter<4> K = Letter<4>(
B1001,
B1010,
B1100,
B1010,
B1001
Letter<3> L = Letter<3>(
B100,
B100,
B100,
B100,
B111
Letter<5> M = Letter<5>(
B10001,
B11011,
B10101,
B10001,
B10001
Letter<5> N = Letter<5>(
B10001,
B11001,
B10101,
B10011,
B10001
Letter<3> O = Letter<3>(
B010,
B101,
B101,
B101,
B010
Letter<3> P = Letter<3>(
B110,
B101,
B110,
B100,
B100
Letter<5> Q = Letter<5>(
B01110,
B10001,
B10101,
B10011,
B01100
Letter<4> R = Letter<4>(
B1110,
B1010,
B1100,
B1010,
B1001
Letter<3> S = Letter<3>(
B011,
B100,
B010,
B001,
B110
Letter<3> T = Letter<3>(
B111,
B010,
B010,
B010,
B010
Letter<3> U = Letter<3>(
B101,
B101,
B101,
B101,
B010
Letter<5> V = Letter<5>(
B10001,
B10001,
B10001,
B01010,
B00100
Letter<5> W = Letter<5>(
B10001,
B10001,
B10001,
B10101,
B01010
Letter<3> X = Letter<3>(
B101,
B101,
B010,
B101,
B101
Letter<3> Y = Letter<3>(
B101,
B101,
B010,
B010,
B010
Letter<3> Z = Letter<3>(
B111,
B001,
B010,
B100,
B111
Letter<1> Ls = Letter<1>(
B0,
B0,
B0,
B0,
B0
Letter<2> Ws = Letter<2>(
B00,
B00,
B00,
B00,
B00
DEFINE THE WORD
const byte WORD_LENGTH = 21;//MAX is around 26
//BaseLetter* word1[WORD_LENGTH] = {&H, &Ls, &E, &Ls, &L, &Ls, &L, &Ls, &O, &Ws, &W, &Ls, &O, &Ls, &R, &Ls, &L, &Ls, &D}; //Hello world 19
BaseLetter* word1[WORD_LENGTH] = {&N, &Ls, &A, &Ls, &T, &Ls, &E, &Ls, &S, &Ws, &A, &Ws, &B, &Ls, &I, &Ls, &T, &Ls, &C, &Ls, &H}; // nates a bitch 21
//BaseLetter* word1[WORD_LENGTH] = {&H, &Ls, &E, &Ls, &L, &Ls, &L, &Ls, &O, &Ws, &W, &Ls, &O, &Ls, &R, &Ls, &L, &Ls, &D}; //hello world
//BaseLetter* word1[WORD_LENGTH] = {&T, &Ls, &H, &Ls, &X, &Ws, &A, &Ls, &L, &Ls, &P, &Ls, &H, &Ls, &A, &Ls, &B, &Ls, &E, &Ls, &T, &Ls, &A}; //thx Alphabeta 23
char Text[5][5*(WORD_LENGTH/2)+(WORD_LENGTH/2)];
pinMode(Row1, OUTPUT);//Row1
pinMode(Row2, OUTPUT);//Row2
pinMode(Row3, OUTPUT);//Row3
pinMode(Row4, OUTPUT);//Row4
pinMode(Row5, OUTPUT);//Row5
pinMode(Col6, OUTPUT);//Col6
pinMode(Col5, OUTPUT);//Col5
pinMode(Col4, OUTPUT);//Col4
pinMode(Col3, OUTPUT);//Col3
pinMode(Col2, OUTPUT);//Col2
pinMode(Col1, OUTPUT);//Col1
for(int i=0; i<WORD_LENGTH; i++){
WordSize = WordSize + (word1[i]->width());
for(Ty=0;Ty<(5*(WORD_LENGTH/2)+(WORD_LENGTH/2));Ty++){
for(Tx=0;Tx<=5;Tx++){
Text[Tx][Ty]=0;
Tx=0;
Ty=0;
for (int wordIndex=0; wordIndex<WORD_LENGTH; wordIndex++){
//loop through all the columns
for (int bit=(word1[wordIndex]->width()-1); bit>=0; bit--){
//loop through all the rows
for (int line=0; line<BaseLetter::NUMBER_OF_LINES; line++){
//print the value at the current letter, at the current line at the current bit
//Serial.print(word1[wordIndex]->get(line,bit),DEC);
Text[Tx][Ty]=int(word1[wordIndex]->get(line,bit));
Tx++;
//Serial.print(Text[Tx][Ty],DEC);
//Serial.println();
Tx=0;
Ty++;
Tx = 0;
Ty = 0;
for(Tx=0;Tx<5;Tx++){
Tx = 0;
Ty = 0;
for(y=0; y <6; y++){
if(t<100){
t++;}
else{
z++;
t=0;}
if(z==((5*(WORD_LENGTH/2)+(WORD_LENGTH/2))-6))
{z=0;}
digitalWrite(Row1, Text[0][y+z]);
digitalWrite(Row2, Text[1][y+z]);
digitalWrite(Row3, Text[2][y+z]);
digitalWrite(Row4, Text[3][y+z]);
digitalWrite(Row5, Text[4][y+z]);
//delay(1000);
if(y==0){
pinMode(Col1,OUTPUT);
digitalWrite(Col1, LOW);
pinMode(Col2,INPUT);
pinMode(Col3,INPUT);
pinMode(Col4,INPUT);
pinMode(Col5,INPUT);
pinMode(Col6,INPUT);}
if(y==1){
//Serial.println("Col2");
pinMode(Col2,OUTPUT);
pinMode(Col1,INPUT);
digitalWrite(Col2, LOW);
if(y==2){
pinMode(Col3,OUTPUT);
digitalWrite(Col3, LOW);
if(y==3){
pinMode(Col4,OUTPUT);
digitalWrite(Col4, LOW);
if(y==4){
pinMode(Col5,OUTPUT);
digitalWrite(Col5, LOW);
if(y==5){
pinMode(Col6,OUTPUT);
digitalWrite(Col6, LOW);}
delay(1);
y=0;
As you can see I have the Custom Letter<> variable and I believe that is what's taking up a lot of the space. If I could off load that to flash it would mean i could make longer sentences in my program. I should mention this is a program that generates an array of 1s and 0s which is then feed to a scrolling LED sign.
