Running Stepper Motor and LEDs Simultaneously!!!
I have 2 pieces of code:
1 that runs a stepper motor (cw, ccw, or stopped) and,
1 that runs LEDs in a specific sequence.
They each work independently perfectly fine but I cant seem to figure out how to make them run together at the same time, I think the issue is coming with not getting the "if" statements synched up right.
Both get a signal from different buttons that send signal to pwm ports.
I am fine with both processes being controlled form one button too!
I attached both separate pieces of code, If someone could help look them over and give me a direction on how to combine them that would be awesome!
I am very new to coding especially with the Arduino so any help would be appreciated. Thanks!
Here are the 2 pieces of code!
//==================Lights Code======================
//================variables===============================
int buttonvalue = 0;
int button = 8;
int green = 7;
int blue = 9;
int red = 5;
//=============void setup======================
void setup(){
pinMode(button, INPUT);
pinMode(green, OUTPUT);
pinMode(blue, OUTPUT);
pinMode(red, OUTPUT);
//=============void loop================================
void loop(){
buttonvalue = digitalRead(button);
if(buttonvalue !=0){
digitalWrite(green, HIGH);
digitalWrite(blue, HIGH);
digitalWrite(red, HIGH);
//1 OFF
digitalWrite(green, LOW);
//1,2 OFF
digitalWrite(blue, LOW);
//1,2,3 OFF
digitalWrite(red, LOW);
delay(200);
delay(200);
delay(200);
delay(200);
delay(200);
delay(200);
delay(200);
delay(200);
delay(200);
delay(200);
delay(200);
delay(200);
//1 OFF
//1,2 OFF
//1,2,3 OFF
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
}else{
digitalWrite(red, LOW);}
//===================motor code========================
//======================Variables===============
int Pin1 = 10;//IN1 is connected to 10
int Pin2 = 11;//IN2 is connected to 11
int Pin3 = 12;//IN3 is connected to 12
int Pin4 = 13;//IN4 is connected to 13
int switchCW =2;//define input pin for CW push button
int switchStop=3;//define input pin for Stop push button
int switchCCW =4;//define input pin for CCW push button
int pole1[] ={0,0,0,0, 0,1,1,1, 0};//pole1, 8 step values
int pole2[] ={0,0,0,1, 1,1,0,0, 0};//pole2, 8 step values
int pole3[] ={0,1,1,1, 0,0,0,0, 0};//pole3, 8 step values
int pole4[] ={1,1,0,0, 0,0,0,1, 0};//pole4, 8 step values
int poleStep = 0;
int dirStatus = 3;// stores direction status 3= stop (do not change)
//==========Void Setup========================================
pinMode(Pin1, OUTPUT);//define pin for ULN2003 in1
pinMode(Pin2, OUTPUT);//define pin for ULN2003 in2
pinMode(Pin3, OUTPUT);//define pin for ULN2003 in3
pinMode(Pin4, OUTPUT);//define pin for ULN2003 in4
pinMode(switchCW,INPUT_PULLUP);// CW push button pin as input
pinMode(switchStop,INPUT_PULLUP);//Stop push button pin as input
pinMode(switchCCW,INPUT_PULLUP);//CCW push button pin as input
//===========void loop============================
if(digitalRead(switchCCW) == LOW)
dirStatus =1;
}else if(digitalRead(switchCW) == LOW)
dirStatus = 2;
}else if(digitalRead(switchStop) == LOW)
dirStatus =3;
if(dirStatus ==1){
poleStep++;
driveStepper(poleStep);
}else if(dirStatus ==2){
poleStep--;
}else{
driveStepper( 8 );
if(poleStep>7){
poleStep=0;
if(poleStep<0){
poleStep=7;
delay(1);
void driveStepper(int c)
digitalWrite(Pin1, pole1
     digitalWrite(Pin2, pole2[c]);
     digitalWrite(Pin3, pole3[c]);
     digitalWrite(Pin4, pole4[c]);
[final_project_lights.ino|attachment](upload://6xAH7KHyd5Cj5t8tZXUH9tvyQtX.ino) (3.8 KB)
[final_project_motor.ino|attachment](upload://fYPwX9PPlgcdWKTsNpdM9u8pBKH.ino) (2.17 KB)
Post the code according to the forum guide please. Many of us read the forum on phones & tablets and cannot open a .ino attachment.
