I’m brand new to arduino and I’ve got an assignment to program a running total calculator using a keypad as an input. I will inout a number, and it should sum it to the previous number and so on, keeping running total of my inputs.
Using the example from arduino IDE, I’ve got it to where I can press a number and print it to my screen.
Where my own coding starts is converting my char key input into an integer as follows:
char key = keypad.getkey();
// converts key variable, which can’t be used in calculations because is char, into integer
int keyNum = key - ‘0’;
//make new variable to store running total
int total = total + keyNum;
if (key) {
Serial.println(total)
Before my setup I stored initial total to be 0 so the code has it. When I upload and input numbers, it only prints the numbers I inout from the keypad and does not keep a running total like I intended.
Ok,so post code.
In code tags
if (key) {
You are creating a new, local, variable named 'total'. If there is a global variable named total it is not being used here.
You could say "total = total + keyNum;" to use the global 'total' (getting rid of the 'int' declaration) or you could use the shortcut for that which is "total += keyNum;"
Hello nathandotts
Welcome to the Arduino fora.
Before you do anything else please take a moment to read General guidance and
How to use this forum
Please post your code, all of it not just a snippet, in code tags as per the instructions.
Please post a schematic so we can see how you have wired things up. What is this keypad you mention? How is it connected?
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 4;
//three columns
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
byte rowPins[ROWS] = {9, 8, 7, 6}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {5, 4, 3, 2}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
int total = 0;
void setup(){
void loop(){
char key = keypad.getKey();
//This converts the char value, which can't be used in math, into an integer by subracting 0 from it
int keyNum = (key - '0');
if (key){
Serial.println(total);
TheMemberFormerlyKnownAsAWOL:
Ok,so post code.
In code tags
#include <Keypad.h>
//three columns
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
int total = 0;
void setup(){
void loop(){
if (key){
This is the keypad I’m using
That’s much better Nathan, although I can’t see your keypad…
I think John has pretty much given you the answer you need.
@nathandotts
Your alternate account has been banned.
Single accounts only from regular users.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Bob.
