Hi, im new to arduino. Im doing a project where im trying to use push buttons to switch between two different programs. So far i've not suceeded. Here is my code:
const int pb1=0, pb2=1, pb3=14, pb4=15, pb5=16, pb6=17, pb7=13, encswt=19, relay= 18;
int i=0, j=0, k=0, l=0, t=0;
int v1=0, v2=0, v3=0, v4=0, v5=0, v6=0, v7=0, enV=0;
int pbCode1=0, pbCode2=0, pbInc100=0, pbInc10=0, pbInc1=0, pbStart=0, pbReset=0, encSwt=0;
float encoder=0;
DDRD=0xff;
DDRB=0xff;
PORTD=0x00;
PORTB=0x00;
pinMode(pb1, INPUT);
pinMode(pb2, INPUT);
pinMode(pb3, INPUT);
pinMode(pb4, INPUT);
pinMode(pb5, INPUT);
pinMode(pb6, INPUT);
pinMode(pb7, INPUT);
pinMode(encswt, INPUT);
pinMode(relay, OUTPUT);
void loop ()
pbCode1= digitalRead(pb1);
pbCode2= digitalRead(pb2);
if ((pbCode1 == HIGH) && (v1==0)) {
t = 0;
v1 = 1;
v2 = 0;
codeAct(1);
if ((pbCode2 == HIGH) && (v2==0)) {
t = 0;
v2 = 1;
v1 = 0;
codeAct(2);
void codeAct (int num)
switch (num)
case 1:
pbInc100= digitalRead(pb3);
pbInc10= digitalRead(pb4);
pbInc1= digitalRead(pb5);
pbStart= digitalRead(pb6);
pbReset= digitalRead(pb7);
encSwt= digitalRead(encswt);
if (t <= 0) {
t=0;
if (t = 3000) {
t=0;
if ((pbInc1 == HIGH)&&(v5==0)) {
v5=1;
t=t+1;
if ((t==10)||(t==20)||(t==30)||(t==40)||(t==50)||(t==60)||(t==70)||(t==80)||(t==90)||
(t==110)||(t==120)||(t==130)||(t==140)||(t==150)||(t==160)||(t==170)||(t==180)||(t==190)||
(t==210)||(t==220)||(t==230)||(t==240)||(t==250)||(t==260)||(t==270)||(t==280)||(t==290)||
(t==310)||(t==320)||(t==330)||(t==340)||(t==350)||(t==360)||(t==370)||(t==380)||(t==390)||
(t==410)||(t==420)||(t==430)||(t==440)||(t==450)||(t==460)||(t==470)||(t==480)||(t==490)||
(t==510)||(t==520)||(t==530)||(t==540)||(t==550)||(t==560)||(t==570)||(t==580)||(t==590)||
(t==610)||(t==620)||(t==630)||(t==640)||(t==650)||(t==660)||(t==670)||(t==680)||(t==690)||
(t==710)||(t==720)||(t==730)||(t==740)||(t==750)||(t==760)||(t==770)||(t==780)||(t==790)||
(t==810)||(t==820)||(t==830)||(t==840)||(t==850)||(t==860)||(t==870)||(t==880)||(t==890)||
(t==910)||(t==920)||(t==930)||(t==940)||(t==950)||(t==960)||(t==970)||(t==980)||(t==990)
(t==1110)||(t==1120)||(t==1130)||(t==1140)||(t==1150)||(t==1160)||(t==1170)||(t==1180)||(t==1190)||
(t==1210)||(t==1220)||(t==1230)||(t==1240)||(t==1250)||(t==1260)||(t==1270)||(t==1280)||(t==1290)||
(t==1310)||(t==1320)||(t==1330)||(t==1340)||(t==1350)||(t==1360)||(t==1370)||(t==1380)||(t==1390)||
(t==1410)||(t==1420)||(t==1430)||(t==1440)||(t==1450)||(t==1460)||(t==1470)||(t==1480)||(t==1490)||
(t==1510)||(t==1520)||(t==1530)||(t==1540)||(t==1550)||(t==1560)||(t==1570)||(t==1580)||(t==1590)||
(t==1610)||(t==1620)||(t==1630)||(t==1640)||(t==1650)||(t==1660)||(t==1670)||(t==1680)||(t==1690)||
(t==1710)||(t==1720)||(t==1730)||(t==1740)||(t==1750)||(t==1760)||(t==1770)||(t==1780)||(t==1790)||
(t==1810)||(t==1820)||(t==1830)||(t==1840)||(t==1850)||(t==1860)||(t==1870)||(t==1880)||(t==1890)||
(t==1910)||(t==1920)||(t==1930)||(t==1940)||(t==1950)||(t==1960)||(t==1970)||(t==1980)||(t==1990)
(t==2110)||(t==2120)||(t==2130)||(t==2140)||(t==2150)||(t==2160)||(t==2170)||(t==2180)||(t==2190)||
(t==2210)||(t==2220)||(t==2230)||(t==2240)||(t==2250)||(t==2260)||(t==2270)||(t==2280)||(t==2290)||
(t==2310)||(t==2320)||(t==2330)||(t==2340)||(t==2350)||(t==2360)||(t==2370)||(t==2380)||(t==2390)||
(t==2410)||(t==2420)||(t==2430)||(t==2440)||(t==2450)||(t==2460)||(t==2470)||(t==2480)||(t==2490)||
(t==2510)||(t==2520)||(t==2530)||(t==2540)||(t==2550)||(t==2560)||(t==2570)||(t==2580)||(t==2590)||
(t==2610)||(t==2620)||(t==2630)||(t==2640)||(t==2650)||(t==2660)||(t==2670)||(t==2680)||(t==2690)||
(t==2710)||(t==2720)||(t==2730)||(t==2740)||(t==2750)||(t==2760)||(t==2770)||(t==2780)||(t==2790)||
(t==2810)||(t==2820)||(t==2830)||(t==2840)||(t==2850)||(t==2860)||(t==2870)||(t==2880)||(t==2890)||
(t==2910)||(t==2920)||(t==2930)||(t==2940)||(t==2950)||(t==2960)||(t==2970)||(t==2980)||(t==2990)) {
t=t-10;
if ((pbInc1 == LOW)&&(v5=1)) {
v5=0;
t=t;
if ((pbInc10 == HIGH)&&(v4==0)) {
v4=1;
t=t+10;
if (
(t==100)||(t==200)||(t==300)||(t==400)||(t==500)||(t==600)||(t==700)||(t==800)||(t==900)||
(t==1100)||(t==1200)||(t==1300)||(t==1400)||(t==1500)||(t==1600)||(t==1700)||(t==1800)||(t==1900)||
(t==2100)||(t==2200)||(t==2300)||(t==2400)||(t==2500)||(t==2600)||(t==2700)||(t==2800)||(t==2900)||
(t==3100)||(t==3200)||(t==3300)||(t==3400)||(t==3500)||(t==3600)||(t==3700)||(t==3800)||(t==3900)||
(t==4100)||(t==4200)||(t==4300)||(t==4400)||(t==4500)||(t==4600)||(t==4700)||(t==4800)||(t==4900)||
(t==5100)||(t==5200)||(t==5300)||(t==5400)||(t==5500)||(t==5600)||(t==5700)||(t==5800)||(t==5900)||
(t==6100)||(t==6200)||(t==6300)||(t==6400)||(t==6500)||(t==6600)||(t==6700)||(t==6800)||(t==6900)||
(t==7100)||(t==7200)||(t==7300)||(t==7400)||(t==7500)||(t==7600)||(t==7700)||(t==7800)||(t==7900)||
(t==8100)||(t==8200)||(t==8300)||(t==8400)||(t==8500)||(t==8600)||(t==8700)||(t==8800)||(t==8900)||
(t==9100)||(t==9200)||(t==9300)||(t==9400)||(t==9500)||(t==9600)||(t==9700)||(t==9800)||(t==9900)) {
t=t-100;
if ((pbInc10 == LOW)&&(v4=1)) {
v4=0;
t=t;
if ((pbInc100 == HIGH)&&(v3==0)) {
v3=1;
t=t+100;
if ((pbInc100 == LOW)&&(v3=1)) {
v3=0;
t=t;
if ((pbReset == HIGH)&&(v7==0)) {
v7=1;
t=0;
if ((pbReset == LOW)&&(v7=1)) {
v7=0;
t=t;
if ((encSwt == HIGH)&&(enV==0)) {
enV=1;
encoder=encoder+1;
if(encoder==((100/24)*20)) {
t=t-1;
encoder=0;
if ((encSwt == LOW)&&(enV=1)) {
enV=0;
t=t;
i=t/1000;
j=(t-(i1000))/100;
k=(t-((i1000)+(j100)))/10;
l=(t-((i1000)+(j100)+(k10)));
turnOnSquare(1);
displayDigit(i);
delay(2);
turnOnSquare(2);
displayDigit(j);
delay(2);
turnOnSquare(3);
displayDigit(k);
delay(2);
turnOnSquare(4);
displayDigit(l);
delay(2);
if ((pbStart == HIGH) && (v6 == 0) && (t > 0)){
digitalWrite(relay, HIGH);
case 2 :
enV=1;
encoder=encoder+1;
t=t+1;
encoder=0;
i=t/1000;
j=(t-(i1000))/100;
turnOnSquare(1);
displayDigit(i);
delay(2);
turnOnSquare(2);
displayDigit(j);
delay(2);
turnOnSquare(3);
displayDigit(k);
delay(2);
turnOnSquare(4);
displayDigit(l);
delay(2);
void turnOnSquare (int num)
int d1=9, d2=10, d3=11, d4=12;
switch(num)
case 1:
digitalWrite(d1, LOW);
digitalWrite(d2, HIGH);
digitalWrite(d3, HIGH);
digitalWrite(d4, HIGH);
case 2:
digitalWrite(d2, LOW);
digitalWrite(d1, HIGH);
case 3:
digitalWrite(d3, LOW);
case 4:
digitalWrite(d4, LOW);
void displayDigit(int num)
switch (num)
case 0:
PORTD=B11111100;
digitalWrite(8, LOW);
case 1:
PORTD=B00011000;
case 2:
PORTD=B01101100;
digitalWrite(8, HIGH);
case 3:
PORTD=B00111100;
case 4:
PORTD=B10011000;
case 5:
PORTD=B10110100;
case 6:
PORTD=B11110100;
case 7:
PORTD=B00011100;
case 8:
PORTD=B11111100;
case 9:
PORTD=B10111100;
Can anyone help....
tag, NOT the QUOTE
