Runs fine connected to PC, resets standalone
hi, beginner here and in a hurry... have this project with pir sensors that trigger an mp3 dfplyer that makes a statue 'talk'
code is pretty simple, so is the hardware, can share of course, got one working on a protoboard, both on pc and standalone... but the one I soldered when running standalone starts a loop, like it runs the setup function again
I had to desolder and soldered again the dfplayer, maybe there's some problem there? it's not too clean... tried 7.5v on vin and 5v on usb, neither worked
I need to have 5 of these working, those are nano clones, thanks for reading and for any advice..!
Welcome to the forum
Please share the details of your project including code, details of the hardware used and a schematic. A picture of a hand drawn circuit is good enough
sure, the arduinos are nano clones, some of them worked fine, for other group had to upload code as 'Duemilanove' or it would fail... but again, it seems to work when connected to pc
#include <DFPlayerMini_Fast.h>
#if !defined(UBRR1H)
#include "SoftwareSerial.h"
SoftwareSerial mySerial(10, 11); //RX, TX
#endif
DFPlayerMini_Fast myMP3;
int pirPin = 3;              //PIR
int ledPin = 13;             //led
int volumen = 25;            //rango de 0 a 30
// SETUP ////////
  pinMode(pirPin, INPUT);
  pinMode(ledPin, OUTPUT);
  // resetear 505 ??????????
  digitalWrite(pirPin, LOW);
  mySerial.begin(9600);
  myMP3.begin(mySerial);
#else
  myMP3.begin(Serial1);
#endif
  // ajustar volumen
  //  Serial.println("");
  //  Serial.println("Ajustar volumen");
  myMP3.volume(volumen);
  // calibrado PIR por 30 segundos / enciende LED 10 veces
  //  Serial.println("calibrado PIR 30 segundos");
  for (int i = 10; i > 0; i--) {
    //    Serial.println( i );
    digitalWrite(ledPin, HIGH);
    digitalWrite(ledPin, LOW);
    delay(2500);
  //  Serial.println("listo...");
// LOOP ////////
  // movimiento detectado ////////
  if (digitalRead(pirPin) == HIGH) {
    // encender led
    //    Serial.println("---------- movimiento..!");
    // reproducir SIGUIENTE audio
    myMP3.playNext();
    delay(2500);
    // mientras suena el audio: función isPlaying()
    while (myMP3.isPlaying()) {
      delay(5000);
    // apagar led
here's an image of setup: https://ibb.co/JtsZD16
thanks for looking at it
What is the purpose of this? If it's to prevent retriggers on the PIR you can do that in hardware on the PIR itself I think. Seems to me the use of all those delays in your code could cause some issues.
hi hallowed, I simplified the code here, removed comments and a pote check -not using it now-
and was using millis and while instead of delays... it makes a little click when checking if audio is done, so I check every 5 seconds, that's the delay you point at... audio files are over a minute
also I got one on a protobard that works ok
edit: I wonder, maybe something to do with serial communication code? I cleared all print lines and comments I think... what could cause the reseting when standalone? maybe I'll solder again all ground connections, what cable do you use for this, 0.25mm is fine? just trying to learn a bit
Anything, really. I don't personally like anything thinner than 22AWG due to breakage but you might be fine. Test the connections with your multimeter. I still don't see the point of that delay in the while() loop. It's going to continually check if the condition is true anyway until it isn't then exit the loop. Adding the delay just pauses everything the Arduino is doing for, in this case, 5 seconds, repeatedly.
ok, thanks hallowed
seems like the function generates a little click noise, it's audible if I do the checking all time... there's a busy pin I could use but would need to wire it... also don't need to be precise with timings, can wait some extra seconds
edit: btw I was using: while (millis() < tiempo + 5000) {} instead of the delay()
Have you just tried playing a file or two in a test sketch to narrow the problem down?
well, it's working now..! wonder how stable it will be then, I just reuploded the same code I think, what's strange with these clones is that you need to declare them as Duemilanove
thanks for your time anyway!
