'runTheLeds' was not declared in this scope
Hi Guys,
I am trying to have the servo move randomly and when it is in its delay i want to be able to push the button and turn the LED on. I tried to put millis code, but it doesnt seem to work on arduino(Servo is moving rapidly, i onlly want to have it move every 5 seconds and be able to push the button for the LED on and off).
It also gave me this error message:
Does anyone have a idea how i can manage this, or what i did wrong?
Thanks alot!
int time;
#include <Servo.h>
long randomNumber;
long servoNumber;
Servo myservo;
int pos = 0;
int buttonPin = 7;
int ledPin = 8;
int buttonstate = 0;
boolean canBePressed = false;
unsigned long previousMillis = 0;
const long interval = 5000;
  myservo.attach(9);
//  randomSeed(analogRead(0));
  pinMode(ledPin, OUTPUT);
  pinMode(buttonPin, INPUT);
//  static unsigned long previousMillis = millis();
//  if (millis() - previousMillis >= interval) {
//    buttonstate = digitalRead(buttonPin);
//    if (buttonstate == HIGH) {
//      if (on == true) {
//        on = false;
//      }  else {
//        on = true;
//    digitalWrite(ledPin, HIGH);
//  else {
//    digitalWrite(ledPin, LOW);
  int timer = 0;
  if(timer = 1000){
    runTheLeds();
  if(timer = 1001){
    timer = 0;
  serial.println(timer);
  public void runTheLeds(){
    randomNumber = random(1000);
    servoNumber = map(randomNumber, 0, 1000, 0, 180);
    myservo.write(servoNumber);
//    Serial.println(servoNumber);
//    Serial.println(buttonstate);
    // We checken of de hoek 90° is.
    if(servoNumber == 90){
//      Serial.println("EMIEL RAM OP DE KNOP");
      canBePressed = true;
    // als de hoek 90° is dan kun je op de button drukken en zet deze de led aan.
    if (canBePressed){
  timer++;
//  previousMillis += interval;
//    randomNumber = random(1000);
////    Serial.print("random:");
////    Serial.println(randomNumber);
//    servoNumber = map(randomNumber, 0, 1000, 0, 180);
////      randomNumber = 90;
////    Serial.print("servo:");
//    myservo.write(servoNumber);
//      for (pos = 0; pos <= 180; pos += 1)
//      myservo.write(pos);
//      for (pos = 180; pos >= 0; pos -= 1)
//  delay(1000);
Have good look at where the runTheLeds() function is situated
Why is it in the middle of the loop() function ?
“public” ?
UKHeliBob:
Hi, I dont know where to place the else? at this moment i dont have any idea what i am doing.
You have placed the definition of a function inside another function
What you probably want is to call the function where you currently have the definition.
The public keyword is not appropriate here.
It would be polite not to post all the code that is commented-out.
EmilOlpinski:
You can call the function from practically anywhere like this
   runTheLeds();
but the actual definition of the function
void runTheLeds(){
etc
etc
must be outside of a function
The problem with your code might be more apparent if you Auto Format it in the IDE, put each { and } on its own line and as suggested, remove the commented out portions of the program.
