Russian Question
Hi everyone! I write as you have already understood from faraway Russia, I was interested in the question as to the Arduino, you can connect a simple screen, such as black and white? And how to get to it any information?
If by simple screen, you are referring to something like this: http://www.sparkfun.com/products/255 then, yes, you can connect them to the Arduino.
Not typical colors, no.
That all depends on which screen you get. There are a number of LCD that can be talked to using the LiquidCrystal library. Other LCDs are serial devices (http://www.sparkfun.com/products/8884), so Serial.print() and/or Serial.write() send data or commands to them.
Welcome;
It is possible to drive a black and white TV (if that is what you meant by screen) with an Arduino, however it is a difficult task with severe timing requirements.
The path most take to interface with a tv or monitor is to utilize a purpose designed shield. Below is one I order that interfaces with any monitor that has a direct video input. You write to the device with simple serial communications commands.
http://www.sparkfun.com/products/9313
Lefty
