RW1990/DS1990 Dallas iButton programming problem
Hello,
I'm trying to use my Arduino UNO as a reader/programmer for RW1990 Dallas iButtons. Reading is working like a charm but I have problem with programming even one iButton. I run the write procedure and when it's finished iButton has still same number.
I've read many articles like on page below and write procedure looks quite proper.
https://blog.danman.eu/cloning-ibutton-using-rw1990-and-avr/
I guess wiring is ok because reading works. I simply connected iButton reader with Arduino's GND, second pin of iButton reader is connected to D8. The same pin is pulled up with resistor to 5V and basically that's all.
What I've already tried to do is:
  • use different pullup resistors (1k8, 2k, 2k2, 4k7),
  • use different codes which was working for other people on other sites,
  • used few different iButtons.
Beside of coding I have doubt about origin of bought iButtons. They are not manufactured by Dallas but distributor declares full compatibility with RW1990/TM1990A.
Here is the code I'm using.
I have already spent few hours about that problem with no luck. Can somebody help me with that issue?
// Based on https://danman.eu/blog/cloning-ibutton-using-rw1990-and-avr/
// and: http://elimelecsarduinoprojects.blogspot.com/2013/06/read-dallas-ibutton-arduino.html
// By Swift Geek 28-08-2015
// TODO: danger to atmega328! Use OpenCollector logic!
// Used 4.8kΩ Pull-up and 3.1 Vcc for arduino/pull-up
#include <OneWire.h>
OneWire ibutton (8); // I button connected on PIN 2.
byte addr[8]; //array to store the Ibutton ID.
void setup(){
void loop(){
  if (!ibutton.search (addr)){//read attached ibutton and asign value to buffer
    ibutton.reset_search();
    delay(200);
    return;
  Serial.print(millis()/1000);
  Serial.print("> ");
  for (byte x = 0; x<8; x++){
    Serial.print(addr[x],HEX); //print the buffer content in LSB. For MSB: for (int x = 8; x>0; x--)
     Serial.print(" ");
  //compute crc//
  byte crc;
  crc = ibutton.crc8(addr, 7);
  Serial.print("CRC: ");
  Serial.println(crc,HEX);
  if ( Serial.read() == 'w' ){
    ibutton.skip();
    ibutton.reset();
    ibutton.write(0x33);
    Serial.print("  ID before write:");
    for (byte x=0; x<8; x++){
      Serial.print(' ');
      Serial.print(ibutton.read(), HEX);
    Serial.print('n');
    Serial.print("  Writing iButton ID:n    ");
    // Hardcode here your desired ID //
    // 01 D5 9F DC 02 00 00 96
    byte newID[8] = {0x01, 0xD5, 0x9F, 0xDC, 0x02, 0x00, 0x00, 0x96};
    ibutton.skip();
    ibutton.reset();
    ibutton.write(0xD5);
      writeByte(newID[x]);
      Serial.print('*');
    Serial.print('n');
    ibutton.reset();
int writeByte(byte data){
  int data_bit;
  for(data_bit=0; data_bit<8; data_bit++){
    if (data & 1){
      digitalWrite(8, LOW); pinMode(8, OUTPUT);
      delayMicroseconds(60);
      pinMode(8, INPUT); digitalWrite(8, HIGH);
      delay(10);
      delay(10);
    data = data >> 1;
  return 0;
[SOLVED]
It was a problem with iButtons. Maybe in previous order they just have send me a DS1990 version instead of RW1990.
Today I received few pieces from two other suppliers and and all of them works without any problem.
